[Geomoose-users] Trouble with PostGis layer on GM 2.2
Brent Fraser
bfraser at geoanalytic.com
Thu Feb 16 09:54:43 EST 2012
Cool. Did you sort out your performance problems with the state-wide
parcel layer?
Best Regards,
Brent Fraser
On 2/16/2012 7:52 AM, Bistrais, Bob wrote:
> Yes, as it turns out, that's what I had to do and it's working now.
> *From:*Brent Fraser [mailto:bfraser at geoanalytic.com]
> *Sent:* Thursday, February 16, 2012 9:37 AM
> *To:* Bistrais, Bob
> *Cc:* Geomoose-users at lists.osgeo.org
> *Subject:* Re: [Geomoose-users] Trouble with PostGis layer on GM 2.2
> If your PostGIS server and mapserver are on different computers, make
> sure you've enabled Postgres to accept remote connects (edit pg_hba.conf).
> Best Regards,
> Brent Fraser
> On 2/15/2012 12:50 PM, Bistrais, Bob wrote:
> Trying to implement some layers through PostGIS, and I'm a PG newbie
> (some of you have seen my struggles on the other lists). But now I am
> having trouble displaying a layer in GeoMoose 2.2. I think this may
> be related to the MapServer version, as this same layer works fine
> with MapServer 6.0.1
> The error message is as follows:
> msPOSTGISLayerOpen(): Query error. Couldn't make connection to DB with
> connect string
> The connection strings:
> DATA "the_geom from bb_connectme_rds USING SRID=26919 USING Unique gid"
> CONNECTION "user=myusername password=mypassword dbname=postgistest
> host=mymachinename port=5432"
> CONNECTIONTYPE postgis
> PROCESSING "CLOSE_CONNECTION=DEFER"
> As I mentioned, this all works fine on another service using MapServer
> 6.0.1. Does PostGis work with GM 2.2? If so, does it look like my
> connection strings are incorrect?
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org <mailto:Geomoose-users at lists.osgeo.org>
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20120216/6423608f/attachment-0001.html
More information about the Geomoose-users
