[Geomoose-users] Highlighted feature not printing
Bistrais, Bob
Bob.Bistrais at maine.gov
Fri Jan 6 16:25:06 EST 2012
A little more background after more investigation- A while back (some of
you may remember) I was having trouble with alpha channels on my
printouts. This was related to the WMS base layers that I use. So I
modified the print.php and print_util.php files. In the renderImage
section, I changed the ImageCopyMerge command to an ImageCopy command.
That seems to be part of the issue. If I go back to the original print
and print_util files, the highlight displays, but again with the black
alpha channels.
We know that the parcelHighlight layer is a bit different because it's
dynamic and not defined in a .map file. Could that be part of the
explanation?
[mailto:geomoose-users-bounces at lists.osgeo.org] On Behalf Of Bistrais,
Bob
Sent: Friday, January 06, 2012 1:56 PM
To: geomoose-users at lists.osgeo.org
Subject: [Geomoose-users] Highlighted feature not printing
OK, I think I broke something here. On one of my applications, selected
features are not appearing highlighted on the printed map. The selected
features ARE highlighted in the application window. I think I must of
broke something. I know it's not something you folks can see without
looking at the code, but can anyone make a suggestion as to where to
look, with respect to the printed layers? I'm looking in print.php, and
I do see that parcelHighlight is one of the layers.
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20120106/c84fd11a/attachment.html
More information about the Geomoose-users
