[Geomoose-users] How to use multiple mapbook?
Brent Fraser
bfraser at geoanalytic.com
Mon Jan 16 13:44:26 EST 2012
The solution given in the wiki is a little terse. I assume when you say
"load only a few mapbook" you mean only a few map-sources.
Basically it suggests (for your case) you create three copies (one for
each of your type of user) of geomoose.html and do a slight modification
to change them into PHP scripts:
geomoose_superuser.php
geomoose_mrc.php
geomoose_user.php
When the person logs in, they would be given a link to one of the files
above, depending on which group they belong to (you need to write the
code to do that).
In each of the above files (mostly consisting of the original
geomoose.html), put a little bit of PHP to set the name of the geomoose
ini file
geomoose_superuser.php:
<?php
session_start();
$_SESSION['settings'] = 'superuser_settings.ini';
<html>
geomoose_mrc.php:
<?php
session_start();
$_SESSION['settings'] = 'mrc_settings.ini';
<html>
geomoose_user.php:
<?php
session_start();
$_SESSION['settings'] = 'user_settings.ini';
<html>
Now create the three ini files named in the geomoose*.php files above,
and edit them to point to three mapbook XML files. Create the three
mapbook XML files giving the user access to the map-sources you want
them to see.
The new config.php file shown in the wiki will get the appropriate ini
filename from the session variable set in the geomoose* php script. It
uses the ini file to look up the right mapbook XML file to send to the
user's browser.
Best Regards,
Brent Fraser
On 1/16/2012 11:09 AM, maddqc wrote:
> Hi all,
> I'm working on a project that I need to use multiple mapbook.
> The problem is that I have tried this "solution"
> (http://geomoose.org/wiki/index.php/Modification_to_Use_Multiple_Map_Books)
> but it doesn't seem to work.
> Maybe I don't understand it very well...
> My goal is that, I have three class of users. One super user who can load
> all mapbook, one "mrc" user that can load only few mapbook and a single user
> who can only load one mapbook.
> I've found a place in the "config.php" where the mapbook is loaded, but i'm
> not sure if I can make a function call to check the type of user and load
> multiple mapbook from there...
> Can anyone help me?
> Thanks alot
> View this message in context: http://geomoose-users.964460.n3.nabble.com/How-to-use-multiple-mapbook-tp3664006p3664006.html
> Sent from the Geomoose-users mailing list archive at Nabble.com.
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users
