[Geomoose-users] Search/Select from Dojo Windows
Matej Mailing
mailing at tam.si
Fri Jul 6 04:18:15 PDT 2012
since Dojo is available in GM, I was thinking of using it to get the
search parameters or to select particular parcels. Side window has
limited width and for example in a Dojo window, you could list a
number of parcels and then when a user clicked "Jump to" on some,
zooming to it should occur. What would be the best way to achieve
this?
TIA,
Matej
More information about the Geomoose-users
