[Geomoose-users] Data Projected in wrong area
Brent Fraser
bfraser at geoanalytic.com
Fri Jul 13 11:05:03 PDT 2012
Joshua,
I see that feature_report.php does a
$layer->queryByRect($mapObj->extent);
which [I think] means that the EXTENT object in your parcel map file
must be set to the min/max coordinates of the target coordinate system
(3857). For the entire world, this would be:
EXTENT -20037508.34 -20037508.34 20037508.34 20037508.34
I think this will work, but I can't recall if this needs to be the
extent in the coordinate system of the source data. If so, we need to
file a ticket to have the PHP do the re-projection (or use $layer->extent?).
Best Regards,
Brent Fraser
On 7/13/2012 11:32 AM, Joshua Meyer wrote:
> Feature Report was working before the coordinate system changes. I have the
> pdf's of the report and jpg of the parcel in the ms_tmp folder. I am using
> GeoMoose 2.6 and MS4W 3.0.6.
> Deputy Joshua Meyer #198
> Lafayette County Sheriff's Department GIS
> 107 S. 11th Street
> Lexington Mo, 64067
> Phone: (660) 259-2796 | Fax: (660) 259-2545
> Cell: (660) 259-1234
> -----Original Message-----
> From: Brent Fraser [mailto:bfraser at geoanalytic.com]
> Sent: Friday, July 13, 2012 10:39 AM
> To: Joshua Meyer
> Cc: geomoose-users at lists.osgeo.org
> Subject: Re: [Geomoose-users] Data Projected in wrong area
> Which version of GM and MS4W? And the Feature Report saw working before the
> coordinate system changes?
> Best Regards,
> Brent Fraser
> On 7/13/2012 9:27 AM, Joshua Meyer wrote:
>> My data is not being projected in the correct location. However,
>> Feature_Report is no longer working correctly. The parcels are no
>> longer showing in the report after using the identify tool. All the
>> information I am wanting is displaying currently but the parcel image is
> not present.
>> 107 S. 11th Street
>> Lexington Mo, 64067
>> From: geomoose-users-bounces at lists.osgeo.org
>> [mailto:geomoose-users-bounces at lists.osgeo.org] On Behalf Of Joshua
>> Meyer
>> Sent: Thursday, July 12, 2012 10:21 AM
>> To: 'Brent Fraser'
>> Thank you very much! That fixed it!
>> Joshua Meyer
>> Sent: Thursday, July 12, 2012 10:04 AM
>> To: Joshua Meyer
>> Joshua,
>> From your posts, I assume you want to display the data in
>> EPSG:3857 to allow overlaying your data on to Google/Bing/Yahoo map
>> layers? And your data is currently stored in
>> NAD_1983_StatePlane_Missouri_West_FIPS_2403_
>> **Feet** which (according to SpatialReference) is not defined by EPSG,
>> but is defined by ESRI.
>> EPSG does define the State Plane zone with units of meters,
>> EPSG:26998, but that won't help.
>> So the only part of the configuration that needs to define the State
>> plane zone is in the LAYER's PROJECTION object (it specifies the
>> coordinate system of the source data). The MAP's PROJECTION object
>> needs to define the target coordinate system (EPSG:3857) as mapserver
>> will handle the re-projection from the source system to the target
>> system. And the GeoMoose needs only to be configured for EPSG:3857
>> since there is no need for it to know about the coordinate system of the
> source data.
>> In your Mapserver map file, the LAYER should have
>> LAYER
>> PROJECTION
>> 'init=esri:102698'
>> END
>> (note the esri, not epsg as the defining authority). And the MAP
>> object should have
>> MAP
>> PROJECTION
>> 'init=epsg:3857'
>> END
>> Best Regards,
>> Brent Fraser
>> On 7/12/2012 8:30 AM, Joshua Meyer wrote:
>>> I may not totally understand your question. Here is the Projection
>>> from one of the map files.
>>> WEB
>>> METADATA
>>> 'ows_title' 'County'
>>> 'ows_srs' 'EPSG:102698 EPSG:26998 EPSG:26915
>>> EPSG:4326 EPSG:900913 EPSG:3857'
>>> 'ows_enable_request' '*'
>>> END
>>> END
>>> PROJECTION
>>> 'init=epsg:26998'
>>> END
>>> I have added the projection to the geomoose.html file.
>>> <script type="text/javascript"
>>> src="projections/EPSG26998.js"></script>
>>> Here is the projection file as I copied off of spatialreference.
>>> Proj4js.defs["EPSG:26998"] = "+proj=tmerc +lat_0=36.16666666666666
>>> +lon_0=-94.5 +k=0.999941177 +x_0=850000 +y_0=0 +ellps=GRS80
>>> ++datum=NAD83 units=m +no_defs";
>>> 107 S. 11th Street
>>> Lexington Mo, 64067
>>> Sent: Thursday, July 12, 2012 9:18 AM
>>> To: Joshua Meyer
>>> So what does your Mapserver mapfile contain in terms of projections?
>>> Best Regards,
>>> Brent Fraser
>>> On 7/12/2012 8:08 AM, Joshua Meyer wrote:
>>>> I have performed all those steps. If I leave the projection in
>>>> mapbook.xml as 3857 my data is projected off the coast of Maine and
>>> rotated clockwise.
>>>> The map files I created(modified) are initialized as 26998. The
>>>> settings.ini and mapbook.xml are both 3857. I have changed the
>>>> projection in settings.ini to 26998 and this has no effect on how my
>>>> data
>>> is projected.
>>>> Joshua Meyer
>>>> From: TC Haddad [mailto:tchaddad at gmail.com]
>>>> Sent: Tuesday, July 10, 2012 3:56 PM
>>>> To: Joshua Meyer
>>>> Make sure to look closely at:
>>>> http://www.geomoose.org/docs/projections.html
>>>> In particular, both parts of Step 2.
>>>> Tanya
>>>> On Tue, Jul 10, 2012 at 12:03 PM, Joshua Meyer
>>>> <jmeyer at lcsheriff.com>
>>> wrote:
>>>>> I am new to GeoMoose. I have added my data and have it projecting.
>>>>> The data is all NAD_1983_StatePlane_Missouri_West_FIPS_2403_Feet.
>>>>> I looked up the information on spatialreference.com and found I
>>>>> needed EPSG:26998. I added the new EPSG as per the GeoMoose
>>>>> instructions on http://www.geomoose.org/docs/projections.html.
>>>>> My data is being projected over Africa. Does anyone know what I am
>>>>> doing wrong?
>>>>> Thanks,
>>>>> Josh
>>>>> _______________________________________________
>>>>> Geomoose-users mailing list
>>>>> Geomoose-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users
