[Geomoose-users] Editing in GeoMoose
Brent Fraser bfraser at geoanalytic.com
Mon Jul 16 13:50:47 PDT 2012
Bbo,
   Comments below...
Best Regards,
Brent Fraser
On 7/16/2012 12:44 PM, Bistrais, Bob wrote:
> While I'm on the topic of editing via GeoMoose...
> I'll soon be developing a GM application which will need to allow
> editing of a layer.  I'd like to ask the user group if any of you
> already have editing capabilities in your applications, or are
> planning to do so?
Yes, using GM 2.4
>    I am interested in both geometry and attribute editing.  Is
> everyone using PostGIS or some other database for editable layers?
I'm using PostGIS (and I'm very happy with it).
> If any has a working application with editing services, can you
> provide a URL so I can take a look?
Not currently, although I do need to set up a demo site soon.  And I
need to implement with the new WFS-T architecture of GM 2.6
> With regard to the Layer Tools in GM, are these easily modified so
> they will work with an editable layer, rather than the default
> graphics layer?
In the 2.6 demo, you just click on the "Census -cities" catalog entry
and you can use the Layer Tools to create/edit/delete features in that
layer (thanks to the new ' activate="true" ' Layer tag in the mapbook )
> Thanks,
> Bob
> *From:*geomoose-users-bounces at lists.osgeo.org
> [mailto:geomoose-users-bounces at lists.osgeo.org] *On Behalf Of
> *Bistrais, Bob
> *Sent:* Monday, July 16, 2012 12:06 PM
> *To:* Dan Little; geomoose-users at lists.osgeo.org
> *Subject:* Re: [Geomoose-users] Editing in GeoMoose
> Thanks Dan.  What about working with ESRI data- SDE or geodatabases?
> Has anyone done that?  Can it be served up as WFS-T?
> *From:*Dan Little [mailto:danlittle at yahoo.com]
> <mailto:[mailto:danlittle at yahoo.com]>
> *Sent:* Thursday, July 12, 2012 9:19 AM
> *To:* Bistrais, Bob; geomoose-users at lists.osgeo.org
> <mailto:geomoose-users at lists.osgeo.org>
> Bob,
> That's not true.  GeoMoose supports editing via WFS-T, it does not
> dictate the source of the WFS-T.  The provider of the WFS-T service
> dictates the underlying data source. For GeoServer, there are a litany
> of database to which it is perfectly happy to connect.  I specifically
> said *databases* because editing a file is really not a good idea.
> There exist a few reasons for this but the most important is probably
> dealing with concurrency.  I tend to use GeoServer for WFS-T testing
> and implementation because it's really damn easy.  (Download, create
> start up script, win.)
> Files, natively, don't have a good way of handling what happens when
> two users do something to the file at the same time.  If both you and
> I both changed the shape of a polygon, or a label, or other attribute,
> at the same time, there's no good way for a file to resolve these
> changes.  A server might be able to do some good work to make this
> type of operation work but I'd highly suggest AVOIDING using a
> multi-user file-based system.  The generally accepted method is to
> make something similar to a PostGIS database and offer exports to
> Shapefiles.
>     *From:*"Bistrais, Bob" <Bob.Bistrais at maine.gov
>     <mailto:Bob.Bistrais at maine.gov>>
>     *To:* "geomoose-users at lists.osgeo.org
>     <mailto:geomoose-users at lists.osgeo.org>"
>     <geomoose-users at lists.osgeo.org
>     <mailto:geomoose-users at lists.osgeo.org>>
>     *Sent:* Wednesday, July 11, 2012 2:38 PM
>     *Subject:* [Geomoose-users] Editing in GeoMoose
>     I was reading the documentation on editing features in GeoMoose
>     2.6.  Now, I'll declare that I did see that only PostGIS data is
>     supported.  That being said, is it possible (and has anyone
>     successfully done so) to edit other data formats. Specifically,
>     shapefiles, or perhaps ESRI Geodatabases?
>     _______________________________________________
>     Geomoose-users mailing list
>     Geomoose-users at lists.osgeo.org <mailto:Geomoose-users at lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20120716/c34a2efe/attachment.html>
More information about the Geomoose-users mailing list
