[Geomoose-users] Installing Geomoose; What next?
Jonathan Moules jonathanmoules at warwickshire.gov.uk
Mon Jul 30 05:12:02 PDT 2012
I've managed to (eventually) get GeoMoose 2.6 & MapServer-4-Windows working
with IIS7. But now when I try and access GeoMoose I get the following:
"Could not load a mapbook. If you are the system administrator, you should
look into this, if you are not the system administrator you should tell
them about this. Suggestions:
The mapbook may not be returning XML.
The mapbook may be returning malformed XML.
PHP may not be responding."
 PHP is running (a simple php script calling *phpinfo();* in the GeoMoose
directory shows that).
Unfortunately at this point the documentation seems to have a gap. I can
find massive amounts of detailed information about what to put in my
mapbooks, what different config settings etc do, but there seems to be a
lack of over-arching documentation. It doesn't tell me clearly where the
mapbooks are, what settings I need to tweak to point them at the mapbooks,
where the config settings.ini file is. Parts of this information seem to be
scattered around (I eventually managed to find
http://geomoose.org/docs/settings.html  (I'd suggest this be pointed to
from "Next steps" here - http://www.geomoose.org/docs/install_ms4w.html )).
Shouldn't the it be loading the demo mapbook? What do I need to change
next? settings.ini is pointing to "mapbook.xml" and there is one of them in
the conf directory too.
Anyone have any thoughts?
Thanks,
Jonathan
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us,  including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20120730/aa8771ac/attachment.html>
More information about the Geomoose-users mailing list
