[Geomoose-users] Failed to open map file error
Bistrais, Bob Bob.Bistrais at maine.gov
Mon Jul 30 07:24:11 PDT 2012
We’ve done some more investigation here.  It looks like the problem was not permissions, but we found that the GeoMoose identify tool would not work with MapServer in a fast CGI mode.  So we put it in a regular CGI mode and it works.  The problem is, now it’s had a negative effect on performance of other applications.
Is this a bug?  Is there a way to do the Identify in a fast CGI mode?
Sent: Friday, June 01, 2012 9:24 AM
To: Bistrais, Bob; geomoose-users at lists.osgeo.org
Subject: Re: [Geomoose-users] Failed to open map file error
Are you sure your web-server user has access to those files?  I'm wondering if the permissions are slightly different on the staging server.
From: "Bistrais, Bob" <Bob.Bistrais at maine.gov<mailto:Bob.Bistrais at maine.gov>>
To: geomoose-users at lists.osgeo.org<mailto:geomoose-users at lists.osgeo.org>
Sent: Thursday, May 31, 2012 5:18 PM
Subject: [Geomoose-users] Failed to open map file error
I’m trying to migrate an application,GeoMoose 2.6 nightly build, from a development server to a staging server.  Most of it works, except the Identify tool.  There, I am getting the following error in Firebug:
Uncaught exception 'MapScriptException' with message 'Failed to open map file "/ms4w_304/apps/StreamBarriers/maps/./towns100.map"' in C:\ms4w_304\apps\StreamBarriers\htdocs\php\identify.php:129
Stack trace:
#0 C:\ms4w_304\apps\StreamBarriers\htdocs\php\identify.php(129): ms_newMapObj('/ms4w_304/apps/...')
#1 {main}
  thrown in C:\ms4w_304\apps\StreamBarriers\htdocs\php\identify.php on line 129
-Basically, it says it can’t open the map file.  But I know that  the path is correct.
Geomoose-users mailing list
Geomoose-users at lists.osgeo.org<mailto:Geomoose-users at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20120730/44c74aee/attachment.html>
More information about the Geomoose-users mailing list
