[Geomoose-users] Failed to open map file error
Dan Little
danlittle at yahoo.com
Fri Jun 1 06:23:55 PDT 2012
Are you sure your web-server user has access to those files? I'm wondering if the permissions are slightly different on the staging server.
>________________________________
> From: "Bistrais, Bob" <Bob.Bistrais at maine.gov>
>To: geomoose-users at lists.osgeo.org
>Sent: Thursday, May 31, 2012 5:18 PM
>Subject: [Geomoose-users] Failed to open map file error
>I’m trying to migrate an application,GeoMoose 2.6 nightly build, from a development server to a staging server. Most of it works, except the Identify tool. There, I am getting the following error in Firebug:
>Uncaught exception 'MapScriptException' with message 'Failed to open map file "/ms4w_304/apps/StreamBarriers/maps/./towns100.map"' in C:\ms4w_304\apps\StreamBarriers\htdocs\php\identify.php:129
>Stack trace:
>#0 C:\ms4w_304\apps\StreamBarriers\htdocs\php\identify.php(129): ms_newMapObj('/ms4w_304/apps/...')
>#1 {main}
> thrown in C:\ms4w_304\apps\StreamBarriers\htdocs\php\identify.php on line 129
>-Basically, it says it can’t open the map file. But I know that the path is correct.
>_______________________________________________
>Geomoose-users mailing list
>Geomoose-users at lists.osgeo.org
>http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20120601/77062ff8/attachment.html>
More information about the Geomoose-users
