[Geomoose-users] Google API upgrade from V2 to V3
Dara Olson dolson at glifwc.org
Thu Mar 1 12:05:19 EST 2012
Thanks to all for your help (and heads up on 2.6 :). Our whole system needs
an upgrade so we will have to postpone for now.
Chi-miigwech!
Dara
On Wed, Feb 29, 2012 at 11:41 AM, Dan Little <danlittle at yahoo.com> wrote:
> To make a plug: 2.6 uses V3 by default.
> *From:* Brent Fraser <bfraser at geoanalytic.com>
> *To:* Dara Olson <dolson at glifwc.org>
> *Cc:* geomoose-users at lists.osgeo.org
> *Sent:* Monday, February 27, 2012 5:34 PM
> *Subject:* Re: [Geomoose-users] Google API upgrade from V2 to V3
>  Dara,
> As I recall using Google API v3 would require referencing the new API
> javascript in GeoMoose.html (no key required with the new API).  It would
> also require changing Geomoose's main.js (somewhere around line 430) from:
>                 var google_translator = {
>                     'physical' : G_PHYSICAL_MAP,
>                     'streets' : null,
>                     'hybrid' : G_HYBRID_MAP,
>                     'satellite' : G_SATELLITE_MAP
> to the new identifiers used (e.g. G_PHYSICAL_MAP is no longer used).  And
> I think it would require an upgrade to a more recent OpenLayers (and that
> may cause other problems).
> Best Regards,
> Brent Fraser
> On 2/27/2012 4:14 PM, Dara Olson wrote:
> Has anyone upgraded to the Google API version 3 for adding background
> layers in your GeoMoose app? If so, do you happen to have an example that
> you could share? I am assuming it would be the same setup as the GeoMoose
> documentation with V2 (except new key/script), but every time I attempt it
> crashes out the site. Any help would be greatly appreciated.
> Thanks!
> Dara
> Geomoose-users mailing listGeomoose-users at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/geomoose-users
Dara Olson
Aquatic Invasive Species Coordinator
Great Lakes Indian Fish & Wildlife Commission
P.O. Box 9, 72682 Maple Street
Odanah, WI 54861
Phone: (715) 682-6619 ext.2129
Email: dolson at glifwc.org
http://maps.glifwc.org
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20120301/626c4935/attachment.html
More information about the Geomoose-users mailing list
