[Geomoose-users] Adding Layer with EPSG:4326
zery.sp at gmail.com
Fri Mar 16 06:44:20 EDT 2012
I'm a new comer, I'm aware that this might have been asked many times, but please let me ask one more time. I'm using GM 2.2 with MS4W, I have disabled all the built in layers and background map, then I add my own mapserver layer and configure everything according to the documentation and some archive post here. The layer is in longlat projection. The map is shown in GM but the problem is I can't get zoom-in or out at the current view.
I believe it is something to do with scales and projection system, but I really can't figure out what to do.
When the map is shown the scales number in the bottom of page is showing 1:15xxxxx (notice that its about 1,5million). And the initial extent is not corresponding to the initial extent value I've set in mapbook.xml. And the max_extent either.
I change ground units from "m" to "dd" and back to "m" nothings happen.
I add ".2" in scales and it only make my map view bigger but still can't do zooming.
So please can someone help me what to do to fixed all this?
Regards,
Zery
Powered by Telkomsel BlackBerry®Powered by Telkomsel BlackBerry®</div>
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20120316/6eb4d597/attachment.html
More information about the Geomoose-users
