[Geomoose-users] Jump To and Change Layer visibility
    Eli Adam
    eadam at co.lincoln.or.us
    Mon Mar 19 10:00:51 EDT 2012
Zery,
> How do you really searching archives in this lists? I could not find any
> option to do so. Do I have to browse each month archives one by one to
> search what I need?
For many OSGeo projects (and others too), you can search the lists
through nabble, http://osgeo-org.1560.n6.nabble.com/ (or
http://www.nabble.com/ and click on OSGeo).  I'll try to make a note
in the documentation about that.
> Anyway, for the geomoose problem;
> 1. I followed this guide but nothing is happen, please guide me to work or
> explain how it really works?
> http://geomoose.org/wiki/index.php/Setup_guide#Update_.22Zoom_to.22_:_You_can_create_groups_and_individuals._You_can_also_do_this_by_referencing_a_shape_file._Check_the_geomoose_info_for_help_on_this.
This documentation has some details specific to some previous Oregon
customizations.  Probably the best documentation for setup (and
specifically zoom to) would be
http://geomoose.org/docs/configuration.html#zoomto
The "Jump To"/"Zoom To" function is to have spatial bookmarks.  You
click on something (like a city name) and it zooms to display the
spatial extent of that city.  It looks like you config has mixed
projections.  You'll want to use the projection of your
http://geomoose.org/docs/configuration.html#projection also in
settings.ini file.  When you say nothing happens, does that mean that
you map doesn't have the 'Jump To:' dropdown with Area1,2,3?  Or that
clicking on those doesn't change the extent?
> 2. How can I interact layers visibility with the Jump To (zoomto) settings?
> Example :
> I have 5 Layer -- A,B,C,D,E  (please ignore the coordinat value)
> <param name="zoomto['Jump To:']"><![CDATA[
>            'Area 1' : [109.996929,-2.795594,110.693635,-2.059638], -----
> Layer A,B,C Not Visible
>            'Area 2' :
> [521238.614537864,4924218.86673578,473921.947801381,4974430.36885032], -----
> Layer C Not Visible
>            'Area 3' :
> [497205.409367,4923984.423582,477595.805945,4941970.52988] ----- Layer A,D,E
> Not Visible
>        ]]></param>
There is nothing preconfigured to change layer visibility with zoom to
extents (unless that also changed scales and there was scale
dependencies on the layers).
HTH, Eli
> Regards,
> Zery
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users
