[Geomoose-users] Identify tool
Eli Adam
eadam at co.lincoln.or.us
Wed Nov 14 10:07:55 PST 2012
On Wed, Nov 14, 2012 at 2:50 AM, moff mofire <githiro at gmail.com> wrote:
> Thank you very much Anderson for your reply. Please find attached my
> mapfile and identify.html.
Moff,
Does you layer display properly?
I'm not sure that you need "TEMPLATE O" in your map file.
Sometimes PostGIS connections can work better more like (copied from,
http://www.mapserver.org/input/vector/postgis.html):
DATA "the_geom from the_database using unique gid using srid=4326"
Eli
> Also this how i have called the layer on mapbook;
> <map-source name="county" type="mapserver">
> <file>./demo/parcels/parcels.map</file>
> <layer name="county" status="on"/>
> <param name="FORMAT" value="image/png;bits=8"/>
> </map-source>
> <catalog>
> <group title="Base Layers">
> <layer title="County" src="county/county" legend="true"
> tip="County layer" show-legend="true" fade="false" unfade="false"/>
> </group>
> </catalog>
> On Wed, Nov 14, 2012 at 12:42 AM, Anderson, Dean <
> anderson.dean at co.polk.or.us> wrote:
>> Please send the mapfile for your identify as an attachment and where you
>> call the mapfile from your mapbook.xml.
>> Thanks
>> Dean
>> On Tue, Nov 13, 2012 at 1:01 PM, moff mofire <githiro at gmail.com> wrote:
>>> Please someone help me solve this problem !
>>> Error Calling the server:
>>> TypeError: Application.getMapSource(
>>> layerName) is undefined
>>> This error appears when i try to use the identify or select tool on a
>>> postgis layer.
>>> I would appreciate any assistance.
>>> Geomoose-users mailing list
>>> Geomoose-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
>> Dean R Anderson
>> IT Director
>> Polk County
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20121114/515b63ff/attachment.html>
More information about the Geomoose-users
