[Geomoose-users] Identify tool
Brent Fraser bfraser at geoanalytic.com
Thu Nov 15 06:47:10 PST 2012
What is your display coordinate system? 4326?
Best Regards,
Brent Fraser
On 11/14/2012 10:48 PM, moff mofire wrote:
> Thank you very much guys for your help. But my problem is still there,
> I have tried to change the tolerance and also add the "the_geom FROM
> county using unique oid using srid=4326 " but still no change. I have
> even tried to rename the postgis table columns but no change. The
> layer is displaying perfectly. find attached the altered mapfile and
> identify.html
> I am so frustrated and i want to use this application for my masters
> degree project.
> On Wed, Nov 14, 2012 at 9:14 PM, Eli Adam <eadam at co.lincoln.or.us
> <mailto:eadam at co.lincoln.or.us>> wrote:
>     On Wed, Nov 14, 2012 at 10:12 AM, Anderson, Dean
>     <anderson.dean at co.polk.or.us <mailto:anderson.dean at co.polk.or.us>>
>     wrote:
>         I think the "TEMPLATE O" is misstyped and should probably be
>         "TOLERANCE 0". At least that would make it more consistent
>         with the demo.
>     Might want to try TOLERANCE 20 too.
>     Eli
>         Dean
>         On Wed, Nov 14, 2012 at 10:07 AM, Eli Adam
>         <eadam at co.lincoln.or.us <mailto:eadam at co.lincoln.or.us>> wrote:
>             On Wed, Nov 14, 2012 at 2:50 AM, moff mofire
>             <githiro at gmail.com <mailto:githiro at gmail.com>> wrote:
>                 Thank you very much Anderson for your reply. Please
>                 find attached my mapfile and identify.html.
>             Moff,
>             Does you layer display properly?
>             I'm not sure that you need "TEMPLATE O" in your map file.
>             Sometimes PostGIS connections can work better more like
>             (copied from,
>             http://www.mapserver.org/input/vector/postgis.html):
>             DATA "the_geom from the_database using unique gid using srid=4326"
>             Eli
>                  Also this how i have called the layer on mapbook;
>                 <map-source name="county" type="mapserver">
>                 <file>./demo/parcels/parcels.map</file>
>                         <layer name="county" status="on"/>
>                         <param name="FORMAT" value="image/png;bits=8"/>
>                     </map-source>
>                 <catalog>
>                         <group title="Base Layers">
>                             <layer title="County" src="county/county"
>                 legend="true" tip="County layer" show-legend="true"
>                 fade="false" unfade="false"/>
>                         </group>
>                     </catalog>
>                 On Wed, Nov 14, 2012 at 12:42 AM, Anderson, Dean
>                 <mailto:anderson.dean at co.polk.or.us>> wrote:
>                     Please send the mapfile for your identify as an
>                     attachment and where you call the mapfile from
>                     your mapbook.xml.
>                     Thanks
>                     Dean
>                     On Tue, Nov 13, 2012 at 1:01 PM, moff mofire
>                         Please someone help me solve this problem !
>                         Error Calling the server:
>                         TypeError: Application.getMapSource(
>                         layerName) is undefined
>                         This error appears when i try to use the
>                         identify or select tool on a postgis layer.
>                         I would appreciate any assistance.
>                         _______________________________________________
>                         Geomoose-users mailing list
>                         Geomoose-users at lists.osgeo.org
>                         <mailto:Geomoose-users at lists.osgeo.org>
>                         http://lists.osgeo.org/mailman/listinfo/geomoose-users
>                     Dean R Anderson
>                     IT Director
>                     Polk County
>         Dean R Anderson
>         IT Director
>         Polk County
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20121115/1bd2d510/attachment-0001.html>
More information about the Geomoose-users mailing list
