[Geomoose-users] multiple applications from same GeoMoose code
Brian Fischer
bfischer at houstoneng.com
Fri Nov 30 08:56:11 PST 2012
At least I'm not alone. Up to this point I have just used web server authentication through Apache or IIS.
I'm thinking something more at the application level, so I can store user settings and preferences. This would likely mean needing a database backend and introducing more server side code (PHP/Python or whatever) along with session variables or cookies.
Brian Fischer, CFM
Principal | GIS Project Manager
Houston Engineering, Inc.
O 763.493.4522 | D 763.493.6664 | M 763.229.2734
From: Bistrais, Bob [mailto:Bob.Bistrais at maine.gov]
Sent: Friday, November 30, 2012 10:40 AM
To: Brian Fischer; geomoose-users at lists.osgeo.org
Subject: RE: multiple applications from same GeoMoose code
Regarding the authentication- some thought, no action. But I see a need in future projects to have some authentication.
From: geomoose-users-bounces at lists.osgeo.org<mailto:geomoose-users-bounces at lists.osgeo.org> [mailto:geomoose-users-bounces at lists.osgeo.org] On Behalf Of Brian Fischer
Sent: Friday, November 30, 2012 11:38 AM
To: geomoose-users at lists.osgeo.org<mailto:geomoose-users at lists.osgeo.org>
Subject: [Geomoose-users] multiple applications from same GeoMoose code
I was just curious if anyone else has thought about or tried any other methods to use multiple mapbooks and settings.ini files with one GeoMoose code folder.
In the past I have used this method and it works well. http://www.geomoose.org/wiki/index.php/Modification_to_Use_Multiple_Map_Books With GeoMoose 2.6 there is another file that is introduced for local_settings.ini.
Also is anyone working on some type of authentication module for GeoMoose. Basically what I'm thinking is depending on who you login as it would configure the catalog differently.
Just wanted to get a thread started if anyone else has worked on this or thinking about it.
Brian Fischer, CFM
[cid:image001.jpg at 01CC3702.356B79C0]
6901 E Fish Lake Rd. , Suite 140 * Maple Grove, MN * 55369
www.houstoneng.com<http://www.houstoneng.com/>
This entire message (including all forwards and replies) and any attachments are for the sole use of the intended recipient(s) and may contain proprietary, confidential, trade secret, work-product, attorney-client or privileged information. Any unauthorized review, use, disclosure or distribution is prohibited and may be a violation of law. If you are not the intended recipient, please contact the sender by reply email and destroy all copies of the original message.
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20121130/97e132ad/attachment.html>
Type: image/jpeg
Desc: image001.jpg
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20121130/97e132ad/attachment.jpg>
More information about the Geomoose-users
