[Geomoose-users] multiple applications from same GeoMoose code
Brent Fraser bfraser at geoanalytic.com
Fri Nov 30 09:05:11 PST 2012
While Bobb and I have had some conversations a few years ago dreaming of
the ultimate authentication system, not much came of it.
On the other hand, I did implement some rudimentary authentication for
my Iceberg GeoMoose site.  We used Django (hey, I didn't choose it!) as
a server-side scripting (Python) framework, and were able to use its
authentication module.
The good news:
     - Django can keep the auth info in PostgreSQL, so it's available to
other scripting languages (e.g. PHP services)
     - all the auth config code exists in Django (so no need to write
anything)
The bad news:
     - we use mapserv.exe and I didn't bother figuring out how to check
the user's credentials for the CGI request (so potential security hole
there).
     - we had to do a little scripting hack to pass the session
authentication from the Python to the PHP environments (so at least you
need to be logged into get the GeoMoose interface and services).
The great thing about having an authenticated site is that it allows
data editing (we used the Feature Editor in v2.4), which opens up the
possibility of a Web-based GIS!
Best Regards,
Brent Fraser
On 11/30/2012 9:38 AM, Brian Fischer wrote:
> I was just curious if anyone else has thought about or tried any other
> methods to use multiple mapbooks and settings.ini files with one
> GeoMoose code folder.
> In the past I have used this method and it works well.
> http://www.geomoose.org/wiki/index.php/Modification_to_Use_Multiple_Map_Books
> With GeoMoose 2.6 there is another file that is introduced for
> local_settings.ini.
> Also is anyone working on some type of authentication module for
> GeoMoose.  Basically what I'm thinking is depending on who you login
> as it would configure the catalog differently.
> Just wanted to get a thread started if anyone else has worked on this
> or thinking about it.
> *Brian Fischer, CFM***
> Principal | GIS Project Manager
> *O*763.493.4522 | *D* 763.493.6664 | *M* 763.229.2734
> cid:image001.jpg at 01CC3702.356B79C0
> 6901 E Fish Lake Rd. , Suite 140 . Maple Grove, MN . 55369
> *www.houstoneng.com* <http://www.houstoneng.com/>****
> This entire message (including all forwards and replies) and any
> attachments are for the sole use of the intended recipient(s) and may
> contain proprietary, confidential, trade secret, work-product,
> attorney-client or privileged information. Any unauthorized review,
> use, disclosure or distribution is prohibited and may be a violation
> of law. If you are not the intended recipient, please contact the
> sender by reply email and destroy all copies of the original message.
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20121130/c4bc6387/attachment.html>
Name: not available
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20121130/c4bc6387/attachment.jpe>
More information about the Geomoose-users mailing list
