[Geomoose-users] multiple applications from same GeoMoose code
Jim Klassen
klassen.js at gmail.com
Fri Nov 30 09:31:47 PST 2012
One thought... settings.ini should be static now (at least for a particular version) so it shouldn't need to be different, local_settings.ini is the one that should be customized.
I've done this by embedding GeoMoose in a Ruby on Rails app. The Rails app provided the mapbook to GeoMoose and tailored it to the particular user. The PHP was stripped out and minimally replaced with Rails equivalents. I think this was back around GeoMoose 2.0. Lately, my method is one static catalog for all, but putting most layers in a CSW server which will only query/return layers the user has permissions to view.
On Nov 30, 2012, at 10:38 AM, Brian Fischer wrote:
> I was just curious if anyone else has thought about or tried any other methods to use multiple mapbooks and settings.ini files with one GeoMoose code folder.
> In the past I have used this method and it works well. http://www.geomoose.org/wiki/index.php/Modification_to_Use_Multiple_Map_Books With GeoMoose 2.6 there is another file that is introduced for local_settings.ini.
> Also is anyone working on some type of authentication module for GeoMoose. Basically what I’m thinking is depending on who you login as it would configure the catalog differently.
> Just wanted to get a thread started if anyone else has worked on this or thinking about it.
> Brian Fischer, CFM
> Principal | GIS Project Manager
> O 763.493.4522 | D 763.493.6664 | M 763.229.2734
> <image001.jpg>
> 6901 E Fish Lake Rd. , Suite 140 • Maple Grove, MN• 55369
> www.houstoneng.com
> This entire message (including all forwards and replies) and any attachments are for the sole use of the intended recipient(s) and may contain proprietary, confidential, trade secret, work-product, attorney-client or privileged information. Any unauthorized review, use, disclosure or distribution is prohibited and may be a violation of law. If you are not the intended recipient, please contact the sender by reply email and destroy all copies of the original message.
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20121130/e23d3104/attachment.html>
More information about the Geomoose-users
