[Geomoose-users] requested image size 2.6 vs 2.2
Jim Klassen
klassen.js at gmail.com
Fri Oct 5 07:55:09 PDT 2012
New question: How can we define layer options (vs parameters) in the mapbook? (Either per layer or set defaults in the configuration section.)
Jim
On Oct 5, 2012, at 7:16 AM, Mark Volz wrote:
> Jim,
> Sorry about the confusion. I think the difference actually has more to do with tiled="true" or tiled="false." I will reexplain.
> In 2.2 Layers that have tiled="true" request enough tiles to cover the map window, and a buffer around the map. When a user pans, the neighboring tiles appear instantly since they have already been buffered. From what I noticed, at 2.6 only enough tiles are requested to cover the map itself. Therefore on a small pan users have to wait to see the tiles.
> In 2.2 Layers that have tiled="false" request an image that is larger than the map window. So panning over a small amount does not make geomoose request a new image. In 2.6 the ratio is set to 1. This means that the requested image is exactly the same size as the map window. This is good because the image is smaller, but a user pans over just a small amount a new image is requested from the server.
> Please see Openlayers Buffer and Ratio for reference.
> I was able to get ratio to work but not buffer.
> ________________________________________
> From: Jim Klassen [klassen.js at gmail.com]
> Sent: Thursday, October 04, 2012 8:49 AM
> To: Matej Mailing
> Cc: Mark Volz; geomoose-users at lists.osgeo.org
> Subject: Re: [Geomoose-users] requested image size 2.6 vs 2.2
> Now I am confused. Are you accessing TileCache or MapServer?
> Type=wms is preferred in 2.6 over type=mapserver presuming you are accessing Mapserver/WMS.
> TileCache/MapCache/OpenStreetMap tiles/etc. would typically use a different type. I don't have my computer in front of me to check which one.
> On Oct 4, 2012, at 7:50, Matej Mailing <mailing at tam.si> wrote:
>> I have type="mapserver" and the path to the mapfile within the file.
>> Is tiled=true available only for type="wms"? I have output already set
>> as WMS in the mapfile, can I use it somehow?
>> Thanks,
>> Matej
>> 2012/10/4 Jim Klassen <klassen.js at gmail.com>:
>>> You're likely something wrong. Do you have tiled=true set in the mapbook?
>>> On Oct 3, 2012, at 3:54 PM, Matej Mailing wrote:
>>>> Hi,
>>>> I would also be interested in this solution. Currently it seems
>>>> tilecache doesn't work - when moving map the surrounding views are
>>>> "not loaded". Is this normal behaviour or am I doing something wrong?
>>>> Thanks,
>>>> Matej
>>>> 2012/9/24 Mark Volz <MarkVolz at co.lyon.mn.us>:
>>>>> Hello,
>>>>> GeoMOOSE appears to request a larger image than what was displayed on the map. This allows for a user to pan around slightly before a new image would need to be requested from the server. It also makes tilled images appear much faster - since the tiles would start to load before a user could pan to the area. Is there any way to configure 2.6 so that we can request larger images so that GM 2.6 behaves more like 2.2?
>>>>> Thanks
>>>>> Mark Volz
>>>>> GIS Specialist
>>>>> _______________________________________________
>>>>> Geomoose-users mailing list
>>>>> Geomoose-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users
