[Geomoose-users] Latitude and Longitude Error... no playing at the poles
Matej Mailing
mailing at tam.si
Thu Oct 11 04:33:31 PDT 2012
I have a GM project with EPSG:4326 data. The file EPSG4326.js exists
on the server and is loaded when the site loads (checked with logs and
also with Firebug)
The file content loaded is:
Proj4js.defs["EPSG:4326"] = "+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs";
In Mapbook I have set
<param name="projection">EPSG:4326</param>
The Identify works with no problems.
What else should I have to change to get it working?
Thanks,
Matej
More information about the Geomoose-users
