[Geomoose-users] Dynamic Zoom
Brian Fischer
bfischer at houstoneng.com
Wed Oct 17 21:07:10 PDT 2012
Bob,
I agree not having to hit the Go button would be nice but that is currently the way GeoMoose works. Highlighting might also be a nice option but once again not built into the zoom to but is built into the query service.
Brian Fischer, CFM
Principal | GIS Project Manager
Houston Engineering, Inc.
O 763.493.4522 | D 763.493.6664 | M 763.229.2734
From: Basques, Bob (CI-StPaul) [mailto:bob.basques at ci.stpaul.mn.us]
Sent: Wednesday, October 17, 2012 11:14 AM
To: Brian Fischer; geomoose-users at lists.osgeo.org
Subject: RE: Dynamic Zoom
Brian,
I just tried it out and went to >> Municipalities >> Frost.
Highlighting of the Frost wasn't obvious, upon closer inspection though, I see the green outline (of Frost?). Would it make any sense to add a highlighting option as a result set, possibly even adding a label and or popup as optional configs.
When the list comes back from the Municipality selection (I assume I can only select one at a time) you should just zoom automatically to the location, the GO button could go away then.
Being able to select more than one item from the list might be a good option to add if it is not already there. Probably not needed for Cities or municipality selections, but for other items it might be useful.
Works real nice as is too. :c) .
Bobb
From: geomoose-users-bounces at lists.osgeo.org<mailto:geomoose-users-bounces at lists.osgeo.org> [mailto:geomoose-users-bounces at lists.osgeo.org] On Behalf Of Brian Fischer
Sent: Wednesday, October 17, 2012 11:04 AM
To: geomoose-users at lists.osgeo.org<mailto:geomoose-users at lists.osgeo.org>
Subject: [Geomoose-users] Dynamic Zoom
We have a couple viewers that were using a "Dynamic Zoom To". It looks like this code was re-written into an extension (http://www.geomoose.org/extensions/DynamicZoom.html), but that it only would work with a GeoMoose 2.4 interface because it is not using the new Dojo interface and dropdown Dijit that is being used for Zoom To in 2.6. So in conclusion this is not working with GM 2.6.
Before we try to tackle this code I just want to make sure no one else has worked on upgrading this extension. Also do others like how the Dynamic Zoom to's work? If you want to see an example take a look at the Zoom to in http://faribault.houstoneng.net/ . Any other suggestions for an improved user experience that we should consider?
Thanks,
Brian
Brian Fischer, CFM
[cid:image001.jpg at 01CC3702.356B79C0]
6901 E Fish Lake Rd. , Suite 140 * Maple Grove, MN * 55369
www.houstoneng.com<http://www.houstoneng.com/>
This entire message (including all forwards and replies) and any attachments are for the sole use of the intended recipient(s) and may contain proprietary, confidential, trade secret, work-product, attorney-client or privileged information. Any unauthorized review, use, disclosure or distribution is prohibited and may be a violation of law. If you are not the intended recipient, please contact the sender by reply email and destroy all copies of the original message.
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20121018/7b465cde/attachment-0001.html>
Type: image/jpeg
Desc: image001.jpg
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20121018/7b465cde/attachment-0001.jpg>
More information about the Geomoose-users
