[Geomoose-users] Displaying the number of resulting features
Eli Adam
eadam at co.lincoln.or.us
Thu Oct 18 07:44:56 PDT 2012
On Thu, Oct 18, 2012 at 6:55 AM, Matej Mailing <mailing at tam.si> wrote:
> Hi,
> I see that there is a number='n' where n replaces the result numbers
> in the query.php. How can we use this correctly returned information
> to display in a template?
If you reference a html template from your map file:
METADATA
'select_record' 'select_survey.html'
'select_header' 'select_header_survey.html'
END
In you html template, you might be able to do something like:
<tr><td>
<b>Results:</b> <span id="numShapes">[nlr]</span>
</td><td
HTH, Eli
> Thanks,
> Matej
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20121018/88dc37cf/attachment.html>
More information about the Geomoose-users
