[Geomoose-users] strange highlight-PSOD problem
Bistrais, Bob
Bob.Bistrais at maine.gov
Thu Oct 18 09:49:22 PDT 2012
After much scrutiny and several times down the wrong path, I found that the problems were in the shapfiles of the orthophoto indices. So I meticulously looked at what was different between a good index layer and one which set off the pink screen. Projection? Nope, those were good. Spatial index? Nope, no issue there. It turns out that every index layer with a problem had an attribute called "group". This item isn't needed by the viewer, and by dropping the "group" item from each index shapefile, the viewer works correctly.
-----Original Message-----
Sent: Monday, October 15, 2012 2:36 PM
To: Bistrais, Bob
Cc: geomoose-users at lists.osgeo.org
Subject: Re: [Geomoose-users] strange highlight-PSOD problem
On Mon, Oct 15, 2012 at 8:05 AM, Bistrais, Bob <Bob.Bistrais at maine.gov> wrote:
> I'm not sure where to begin looking into this problem. In my
> basemap-orthoimagery viewer,
> http://mapserver.maine.gov/basemap/index.html#
> We are getting a strange problem. If one selects municipal imagery
> for downloading, the selection process works, but the selection does
> not highlight, instead we get the dreaded pink screen of death. This
> occurs when selecting some image layers, but not all of them. The
> NAIP series appear to be fine, the selection highlights properly.
> But, for example, the municipal orthoimagery layers have this problem.
> I tried to turn on the debug with highlight.map, but that didn't write anything to the error log.
> Any ideas where to start looking?
I selected some Augusta/Manchester imagery and got the pink screen then (in firefox: tools-->page info-->Media) went to the url of the pink tile, http://mapserver.maine.gov/cgi-bin/mapserv.exe?service=WMS&version=1.1.1&request=GetMap&styles=&format=image%2Fjpeg&LAYERS=highlight&TRANSPARENT=true&MAP=%2Fms4w_304%2Ftmp%2Fms_tmp%2F%2Fselect_68441350325488.map&FORMAT=image%2Fpng&SRS=EPSG%3A26919&BBOX=374887.49149445,4873840.1331571,516143.11974579,4960061.1010507&WIDTH=924&HEIGHT=564
which offered to download mapserv.exe which I saved then opened with a test editor to see:
<?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?> <!DOCTYPE ServiceExceptionReport SYSTEM "http://schemas.opengis.net/wms/1.1.1/exception_1_1_1.dtd">
<ServiceExceptionReport version="1.1.1"> <ServiceException>
msDrawMap(): Image handling error. Failed to draw layer named 'selected'.
msOGRFileOpen(): OGR error. GetLayer(features) failed for OGR connection `/ms4w_304/tmp/ms_tmp//select_68441350325488.db'.
</ServiceException>
</ServiceExceptionReport>
This is often how MapServer wms errors are delivered.
HTH, Eli
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users
