[Geomoose-users] Auto-refreshing
Matej Mailing mailing at tam.si
Thu Oct 18 11:29:42 PDT 2012
I have found out the 'cycle' option in layer_controls (config.js):
'cycle' : {on: false, tip: 'Refresh ${layer} every 10 seconds', seconds: 10},
Is this thing "alive"?
Regards,
Matej
2012/10/18 Brian Fischer <bfischer at houstoneng.com>:
> I don't believe this was carried over.  You would likely need to write an extension to do this.  There is example code in GM 2.2 I believe.  I have used it once for some weather radar layers.
> Brian Fischer, CFM
> Principal | GIS Project Manager
> Houston Engineering, Inc.
> O 763.493.4522 | D 763.493.6664 | M 763.229.2734
> -----Original Message-----
> From: geomoose-users-bounces at lists.osgeo.org [mailto:geomoose-users-bounces at lists.osgeo.org] On Behalf Of Matej Mailing
> Sent: Wednesday, October 17, 2012 5:02 AM
> To: GeoMOOSE Users List
> Subject: [Geomoose-users] Auto-refreshing
> Hi,
> if I rembember correctly from 1.X versions that there was a way to turn on and off the auto-refreshing of the specific layers on the specified interval. Is this possible in 2.6?
> Thanks,
> Matej
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users mailing list
