[Geomoose-users] strange highlight-PSOD problem
Bistrais, Bob
Bob.Bistrais at maine.gov
Thu Oct 18 11:33:29 PDT 2012
Well, I know that "group" is a keyword in MapServer .map files, so it may be reserved and therefore caused the problem.
-----Original Message-----
From: geomoose-users-bounces at lists.osgeo.org [mailto:geomoose-users-bounces at lists.osgeo.org] On Behalf Of Basques, Bob (CI-StPaul)
Sent: Thursday, October 18, 2012 2:30 PM
To: Jim Klassen; geomoose-users at lists.osgeo.org
Subject: Re: [Geomoose-users] strange highlight-PSOD problem
Is "group" possibly a keyword that is not supposed to be used somewhere. I remember something some time back about prohibited column names for SHP files for example . . .
Bobb
>> users-bounces at lists.osgeo.org] On Behalf Of Jim Klassen
>> Sent: Thursday, October 18, 2012 12:11 PM
>> To: geomoose-users at lists.osgeo.org
>> Thanks for sharing your solution. It sounds like you may have
>> found a bug in MapServer.
>> On 10/18/2012 11:49 AM, Bistrais, Bob wrote:
>> > After much scrutiny and several times down the wrong path, I
>> found that the problems were in the shapfiles of the orthophoto
>> indices. So I meticulously looked at what was different between a
>> good index layer and one which set off the pink screen.
>> Projection? Nope, those were good. Spatial index? Nope, no issue
>> there. It turns out that every index layer with a problem had an
>> attribute called "group". This item isn't needed by the viewer, and
>> by dropping the "group" item from each index shapefile, the viewer
>> works correctly.
>> > From: Eli Adam [mailto:eadam at co.lincoln.or.us] > Sent: Monday,
>> October 15, 2012 2:36 PM > To: Bistrais, Bob > Cc:
>> geomoose-users at lists.osgeo.org > Subject: Re: [Geomoose-users]
>> strange highlight-PSOD problem > > On Mon, Oct 15, 2012 at 8:05 AM,
>> Bistrais, Bob <Bob.Bistrais at maine.gov> wrote:
>> >> I'm not sure where to begin looking into this problem. In my >>
>> basemap-orthoimagery viewer, >>
>> http://mapserver.maine.gov/basemap/index.html#
>> >> We are getting a strange problem. If one selects municipal
>> imagery >> for downloading, the selection process works, but the
>> selection does >> not highlight, instead we get the dreaded pink
>> screen of death. This >> occurs when selecting some image layers,
>> but not all of them.
>> The
>> >> NAIP series appear to be fine, the selection highlights
>> properly.
>> >> But, for example, the municipal orthoimagery layers have this
>> problem.
>> >> I tried to turn on the debug with highlight.map, but that didn't
>> write anything to the error log.
>> >> Any ideas where to start looking?
>> > I selected some Augusta/Manchester imagery and got the pink
>> screen > then (in firefox: tools-->page info-->Media) went to the
>> url of the > pink tile, > http://mapserver.maine.gov/cgi-
>> bin/mapserv.exe?service=WMS&version=1.1
>> .1&request=GetMap&styles=&format=image%2Fjpeg&LAYERS=highlight&TR
>> ANSPA
>> RENT=true&MAP=%2Fms4w_304%2Ftmp%2Fms_tmp%2F%2Fselect_684413503254
>> 88.ma
>> p&FORMAT=image%2Fpng&SRS=EPSG%3A26919&BBOX=374887.49149445,487384
>> 0.133
>> > 1571,516143.11974579,4960061.1010507&WIDTH=924&HEIGHT=564
>> > which offered to download mapserv.exe which I saved then opened
>> with a test editor to see:
>> > <?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?>
>> <!DOCTYPE > ServiceExceptionReport SYSTEM >
>> "http://schemas.opengis.net/wms/1.1.1/exception_1_1_1.dtd">
>> > <ServiceExceptionReport version="1.1.1"> <ServiceException> >
>> msDrawMap(): Image handling error. Failed to draw layer named
>> 'selected'.
>> > msOGRFileOpen(): OGR error. GetLayer(features) failed for OGR
>> connection `/ms4w_304/tmp/ms_tmp//select_68441350325488.db'.
>> > </ServiceException>
>> > </ServiceExceptionReport>
>> > This is often how MapServer wms errors are delivered.
>> > HTH, Eli
>> >> _______________________________________________
>> >> Geomoose-users mailing list
>> >> Geomoose-users at lists.osgeo.org
>> >> http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users
