[Geomoose-users] Layer Display Error
Efstathios Arapostathis
e.arapostathis at gmail.com
Fri Oct 19 01:34:20 PDT 2012
Hi guys,
Apparently I have not used geomoose for a long period of time, so I'm
stucked again in issues that I have solved in the past.
I was wondering if you could provide me with some feedback. I'm having
problems in displaying a postgis layer in geomoose 2.6. I'm getting a pink
image and when I'm trying to follow the link (from mozilla firefox on the
sub menu tools-->page info-->multimedia) no error message is provided.
Instead a popup window appears in order to save mapserv.exe file(!!)
I enabled debug in the map file and this is the log I'm receiving. I cannot
really understand it. Could anyone help me please?
[Fri Oct 19 11:20:39 2012].971000 CGI Request 1 on process 4992
[Fri Oct 19 11:20:37 2012].936000 CGI Request 1 on process 3524
[Fri Oct 19 11:20:37 2012].940000 msDrawMap(): rendering using outputformat
named agg/png (AGG/PNG).
[Fri Oct 19 11:20:40 2012].106000 msPostGISLayerWhichShapes(): Query error.
Error (ERROR: relation "agenda" does not exist
LINE 1: ...e_2D("the_geom"),'NDR'),'hex') as geom,"gid" from Agenda whe...
) executing query: select
encode(ST_AsBinary(ST_Force_2D("the_geom"),'NDR'),'hex') as geom,"gid" from
Agenda where the_geom && GeomFromText('POLYGON((2646964.79596457
4577985.29374734,2646964.79596457 4584071.59212366,2657943.06415043
4584071.59212366,2657943.06415043 4577985.29374734,2646964.79596457
4577985.29374734))',find_srid('','Agenda','the_geom'))
[Fri Oct 19 11:20:40 2012].106000 msDrawMap(): Image handling error. Failed
to draw layer named 'Agenda'.
[Fri Oct 19 11:20:38 2012].473000 CGI Request 1 on process 4848
[Fri Oct 19 11:20:38 2012].619000 msDrawMap(): rendering using outputformat
[Fri Oct 19 11:20:40 2012].199000 msPostGISLayerWhichShapes(): Query error.
"Agenda" Is the name of the Table of the "CulturalGIS" database. It is a
POINT PostGIS Layer, I'm attaching the map file.
Thanks in advance for any responses
Stathis
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20121019/7fc8fd2e/attachment.html>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20121019/7fc8fd2e/attachment.obj>
More information about the Geomoose-users
