[Geomoose-users] POSTGIS required for adding layers?
Brian Fischer
bfischer at houstoneng.com
Sun Oct 21 08:59:10 PDT 2012
Jon,
Basically you have a 2 primary routes of adding your own data to GeoMoose.
1) You can consume a map layer as a service directly by GeoMoose (such as WMS, ESRI ArcServer, XYZ tiles, google, etc). There are limitations with some of these formats and you have to be able to publish your data as one of these.
2) You can use MapServer to publish your data as a service. MapServer supports a number of different types of data sources through GDAL/OGR. See http://mapserver.org/input/index.html
Hope this helps.
Brian Fischer, CFM
Principal | GIS Project Manager
Houston Engineering, Inc.
O 763.493.4522 | D 763.493.6664 | M 763.229.2734
From: geomoose-users-bounces at lists.osgeo.org [mailto:geomoose-users-bounces at lists.osgeo.org] On Behalf Of Lee, Jon
Sent: Friday, October 19, 2012 6:34 PM
To: geomoose-users at lists.osgeo.org
Subject: [Geomoose-users] POSTGIS required for adding layers?
Hi guys,
Just one question for clarification. Is PostGis required for adding layers to Geomoose 2.6? Thanks.
Sincerely,
Jon
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20121021/0d39ab0f/attachment.html>
More information about the Geomoose-users
