[Geomoose-users] GM 2.6 Select Service not working
Nayna Nayate
nayna.nayate at gis.leg.mn
Thu Oct 25 10:46:52 PDT 2012
Thank you for the suggestion. I figured it out. My path was incorrect because the select uses the "root" path and I had a full path name in my mapfile. The path name was being displayed twice. I just set the root in the local_settings.ini t to blank and it worked.
Sent: 25 October 2012 10:22
To: Nayna Nayate
Cc: geomoose-users at lists.osgeo.org
Subject: Re: [Geomoose-users] GM 2.6 Select Service not working
On Thu, Oct 25, 2012 at 6:32 AM, Nayna Nayate <nayna.nayate at gis.leg.mn<mailto:nayna.nayate at gis.leg.mn>> wrote:
Hi all,
I am trying to get the services in the demo to work. The identify service works but none of the others (select, search parcels or print) work. I have not changed anything other than make a local setting.ini file. I think I'm missing something very obvious but cannot seem to pinpoint it.
Upon a select or print I get the following error
What did you put in the local_settings.ini? There are docs on that here, http://www.geomoose.org/docs/settings.html
The service you called did not return valid XML. If you are the system administrator, you should look into this, if you are not the system administrator you should tell them about this.
For Search parcels when I look for the name "smith" for which there are plenty records, I get
GeoMOOSE Item Query Service
No results found for your query!
You can get more detailed information using firebug with firefox. For instance, on the demo, I did a parcel search for smith and on the post got this:
highlight=true&mode=search&layer0=parcels%2Fparcels&template0=itemquery&fieldname0=OWNER_NAME&comparitor0=like-icase&value0=smith&fieldname1=FIN_SQ_FT&operator1=or&comparitor1=gt&value1=&dojo.preventCache=1351177986847
and the response got this:
<results n='83'><script><![CDATA[GeoMOOSE.turnLayerOn('parcels/parcels');
GeoMOOSE.changeLayerUrl('highlight', './php/query.php');GeoMOOSE.clearLayerParameters('highlight');GeoMOOSE.updateLayerParameters('highlight', {'highlight' : 'true','layer0' : 'parcels/parcels','template0' : 'itemquery','fieldname0' : 'OWNER_NAME','comparitor0' : 'like-icase','value0' : 'smith','fieldname1' : 'FIN_SQ_FT','operator1' : 'or','comparitor1' : 'gt','value1' : '','dojo_preventCache' : '1351177986847','TRANSPARENT' : 'true','FORMAT' : 'image/png','LAYERS' : 'highlight'});GeoMOOSE.turnLayerOn('highlight/highlight');GeoMOOSE.refreshLayers('highlight/highlight');]]></script><html><![CDATA[<!-- MapServer Template -->
<b>GeoMOOSE Item Query Results</b><br/>
<a id="gm-parcel-350010002101" class='sprite-control sprite-control-find-selected' style="padding-left: 22px" parcel-shape="496463,4932245 496788,4932244 496863,4932244 496863,4932234 496867,4931899 496867,4931876 496466,4931877 496466,4931900 496463,4932235 496463,4932245" href="javascript:GeoMOOSE.zoomToPointsList(dojo.byId('gm-parcel-350010002101').getAttribute('parcel-shape'), 'EPSG:26915');">350010002101</a><br/>
Robert Smith<br/>
<br/>
<a id="gm-parcel-350010001201" class='sprite-control sprite-control-find-selected' style="padding-left: 22px" parcel-shape="496226,4932236 496227,4932098 496063,4932098 496062,4932236 496062,4932246 496226,4932246 496226,4932236" href="javascript:GeoMOOSE.zoomToPointsList(dojo.byId('gm-parcel-350010001201').getAttribute('parcel-shape'), 'EPSG:26915');">350010001201</a><br/>
[lots more]
Wilson Smith<br/>
<br/>
<a id="gm-parcel-130360001025" class='sprite-control sprite-control-find-selected' style="padding-left: 22px" parcel-shape="486724,4933889 486725,4933488 486727,4933086 486325,4933089 486321,4933892 486724,4933889" href="javascript:GeoMOOSE.zoomToPointsList(dojo.byId('gm-parcel-130360001025').getAttribute('parcel-shape'), 'EPSG:26915');">130360001025</a><br/>
Wilton Smith<br/>
<br/>
<!-- Place Holder -->
]]></html></results>
HTH, Eli
Any help is appreciated!
Thanks
Nayna
Geomoose-users mailing list
Geomoose-users at lists.osgeo.org<mailto:Geomoose-users at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20121025/5f2611ed/attachment.html>
More information about the Geomoose-users
