[Geomoose-users] Identify, services, and the PSOD
Jason Menard menard.jason at gmail.com
Thu Oct 25 11:30:41 PDT 2012
79 is the 'identify_record' line.
But that wasn't the problem, it seems.. debugger just reported
[Thu Oct 25 14:21:36 2012].904000 msLoadMap(): Unknown identifier. Parsing
error near (METADATA):(line 77)
[Thu Oct 25 14:21:36 2012].904000 msFreeMap(): freeing map at 02BA21D0.
Where line 77 is the METADATA tag.  Turns out the CLASS section above
didn't have an END tag.  Let's hear it for Notepad++.
And really, the list archive doesn't have enough silly questions to help
noobs like myself figure all this out, so really, my posts are a public
service.... :)
Result: PSOD gone.  Identify still doesn't work for the point feature, but
at least now I have one problem instead of two.
Thanks,
jason
Jason Menard
On Thu, Oct 25, 2012 at 2:18 PM, Bistrais, Bob <Bob.Bistrais at maine.gov>wrote:
>  Just for starters, I’d try removing the tab and just use some spaces.****
> Another thing I’d suggest is removing that #drill down line with the
> comment.  Might not be the problem, but it can be eliminated as the
> possibility.****
> Which one is line 79?****
> *From:* Jason Menard [mailto:menard.jason at gmail.com]
> *Sent:* Thursday, October 25, 2012 2:12 PM
> *To:* Bistrais, Bob
> *Cc:* geomoose-users at lists.osgeo.org
> *Subject:* Re: [Geomoose-users] Identify, services, and the PSOD****
> Hi Bob,****
> Yep, local_settings.ini set to maps.  :)****
> The metadata items are separated by a TAB.  So the code in the .MAP file
> is:****
>                         METADATA****
>                         # drill-down identify service record.****
>                                     'identify_record'
> 'templates/identify.html'****
>                         END****
>                         TOLERANCE 0****
>              END****
> And all identify.html is is this (all I want is an ID returned):****
> <!-- MapServer Template -->****
> <tr bgcolor="#DEE5EB"><td colspan="2"><b><u>Gate Valves</u></b></tr>****
> <tr>****
> <td align="right"><b>ID: </b></td>****
> <td>[ID]</td>****
> </tr>****
> <tr>****
> <td> </td>****
> <td> </td>****
> </tr>****
> The debugger returns this:****
> [Thu Oct 25 10:11:32 2012].534000 msLoadMap(): Unknown identifier.
> Parsing error near (identify_record):(line 79)****
> ... Line 79 is the line.  ****
> I can see why it might not work, but the PSOD is an extra wrinkle of
> confusion.****
> Thanks,****
> Jason****
> Jason Menard
> On Thu, Oct 25, 2012 at 1:56 PM, Bistrais, Bob <Bob.Bistrais at maine.gov>
> wrote:****
> One thing to check just to be sure, in conf\local_settings.ini, make sure
> the root is set for the location of your maps directory.****
> *From:* geomoose-users-bounces at lists.osgeo.org [mailto:
> geomoose-users-bounces at lists.osgeo.org] *On Behalf Of *Bistrais, Bob
> *Sent:* Thursday, October 25, 2012 1:54 PM
> *To:* Jason Menard; geomoose-users at lists.osgeo.org
> It would be good if we could see your code.  So the point layer draws, but
> adding those items to the metadata section breaks it?  Or does the act of
> trying to Identify give you the PSOD?****
> Are those metadata items in quotes, with a space between them? (as in your
> message)****
> mailto:geomoose-users-bounces at lists.osgeo.org<geomoose-users-bounces at lists.osgeo.org>]
> *On Behalf Of *Jason Menard
> *Sent:* Thursday, October 25, 2012 1:48 PM
> *To:* geomoose-users at lists.osgeo.org
> *Subject:* [Geomoose-users] Identify, services, and the PSOD****
> Hi all,****
> I am slogging through service configuration.  I have parcels in my
> datasets, I can get those to work fine with Identify just fine (and Search
> Parcels too).  But when I try to add some point features, adding
> the 'identify_record'            'templates/identify.html' to the METADATA
> section of the .MAP file breaks the layer and gives me the PSOD.  I'm
> pretty sure I have the templates configured correctly (though with me, you
> never know), but I can't think why I'd get the PSOD.****
> Any ideas?****
> Thanks!****
> -jason
> Jason Menard
> menard.jason at gmail.com****
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20121025/4730a84b/attachment.html>
More information about the Geomoose-users mailing list
