[Geomoose-users] Prolem with Identify/select on a layer
Brent Fraser bfraser at geoanalytic.com
Thu Sep 6 07:58:40 PDT 2012
Bob,
Try adding
TOLERANCE 0
and maybe
TEMPLATE 'placeholder'
to the LAYER def
Best Regards,
Brent Fraser
On 9/6/2012 8:47 AM, Bistrais, Bob wrote:
> (Also posted to MapServer list)
> I am having trouble with a specific layer. This shows up and displays
> correctly, but I can't get it  to work with Identify or Select.  It
> just doesn't show up in the results.  The error log says:
> msQueryByPoint(): Search returned no results. No matching record(s) found.
> As best as I can tell, I have the coding in there correctly:
>   LAYER
>     NAME 'GeoLibrary_2ft_2003_2005'
>     GROUP 'GeoLibrary_2ft_2003_2005'
>     DATA "/mapserver_data/basemap/ortho2f/ortho2f_index2.shp"
>     STATUS on
>     TYPE polygon
>     TRANSPARENCY 50
>     METADATA
>       "opacity" "50"
>       "queryable" "True"
>       "DESCRIPTION" "GeoLibrary 2ft index"
>       "SEARCHFIELD" "tile"
>       "fields" "tile:tilename,location,link"
>       "hyperlink" "link"
>       "wms_title" "GeoLibrary 2ft Index"
>       'identify_record' 'templates/identify_geolib.html'
>       'select_record' 'templates/ortho_result.html'
>       'select_header' 'templates/ortho_header.html'
>     END
>   PROJECTION
>     "init=epsg:26919"
>   END
>     CLASS
> #      NAME "Geolibrary 2ft Index"
>       STYLE
>        OUTLINECOLOR 255 0 255
>        WIDTH 2
>       END
>     END
>   END
> ...And as mentioned, the layer shows up as expected.  What am I
> missing here??
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20120906/7fb6689c/attachment.html>
More information about the Geomoose-users mailing list
