[Geomoose-users] Identify not working
Matej Mailing
mailing at tam.si
Wed Sep 19 14:04:24 PDT 2012
Oh yeah, that was it!!!!
Thanks to all of you :-)
Regards,
Matej
2012/9/19 Anderson, Dean <anderson.dean at co.polk.or.us>:
> This may or may not be it. I had similar issues in a 2.4 app and expanded my
> search tolerance which let me find them as follows:
> LAYER
> NAME "control"
> DATA './data/control'
> STATUS ON
> TYPE point
> TOLERANCE 50
> TOLERANCEUNITS FEET
> Expanding tolerance let me identify them.
> Hope it helps.
> Dean
> On Wed, Sep 19, 2012 at 1:42 PM, Matej Mailing <mailing at tam.si> wrote:
>> Hi,
>> the issue with not-passed projection is solved - it seems I have
>> removed input type="projection" from the identify service by mistake.
>> Now when turning on the debug mode for identify.map I get no more
>> errors and warnings, just this one:
>> "Warning: mapObj::queryByPoint(): [MapServer Error]: msQueryByPoint():
>> No matching record(s) found.
>> in /var/www/elgismap/php/identify.php on line 170"
>> When turning debug off, I get no results.
>> Map file:
>> MAP NAME my_layer
>> DEBUG 5
>> EXTENT 484000 90000 620000 190000
>> STATUS ON
>> SIZE 2000 2000
>> TRANSPARENT TRUE
>> UNITS METERS
>> IMAGECOLOR 255 255 255
>> IMAGETYPE PNG
>> INCLUDE "../globals.map"
>> PROJECTION
>> "init=epsg:4326"
>> END
>> QUERYMAP
>> STATUS ON
>> STYLE SELECTED
>> END
>> WEB
>> METADATA
>> "wms_title" "my_layer"
>> "wms_srs" "EPSG:4326"
>> "wms_enable_request" "*"
>> END
>> QUERYFORMAT "text/xml"
>> INCLUDE "../temp_directory.map"
>> IMAGEPATH "/var/www/gm/tmp/"
>> IMAGEURL "/gm/tmp/"
>> END
>> LEGEND
>> STATUS ON
>> LABEL
>> TYPE TRUETYPE
>> FONT vera_sans
>> SIZE 8
>> COLOR 0 0 0
>> END
>> END
>> LAYER
>> NAME "layer_name"
>> TYPE POINT
>> STATUS DEFAULT
>> CONNECTIONTYPE POSTGIS
>> CONNECTION "host=localhost ... port=5432 options='-c
>> client_encoding=UTF8'"
>> DATA "wkb_geometry from table"
>> CLASS
>> TEXT '[text]'
>> COLOR 200 23 255
>> SYMBOL 'circle'
>> MAXSIZE 13
>> MINSIZE 10
>> LABEL
>> TYPE TRUETYPE
>> OFFSET 2 2
>> FONT timesi
>> POSITION ur
>> ANTIALIAS true
>> MINSIZE 12
>> MAXSIZE 15
>> COLOR 10 120 80
>> END
>> END
>> METADATA
>> 'identify_record' 'templates/identify.html'
>> END
>> TOLERANCE 0
>> END
>> END
>> Thanks,
>> Matej
>> > So - what does your map file look like?
>> > THanks
>> > Dean
>> > On Wed, Sep 19, 2012 at 1:20 PM, Matej Mailing <mailing at tam.si> wrote:
>> >> Hi,
>> >> wms_* entries were commented out (non-wms_* were not), but also after
>> >> uncommenting them the situation is the same. When checking the POST
>> >> parameters for identify.php with Firebug, there is no projection. The
>> >> projection file (Javascript) is successfully loaded on the site and
>> >> the EPSG:4326 is set both in mapbook.xml and settings.ini (in [map]
>> >> section).
>> >> The parcels demo has data stored in SHP and we are using PostGIS for
>> >> it. I have gone through both map files and the only difference is that
>> >> in the WEB METADATA of our mapfile we have wms_title, wms_srs and
>> >> wms_enable_request and in parcels mapfile there are ows_* tags ...
>> >> Thanks,
>> >> Matej
>> >> 2012/9/19 Brent Fraser <bfraser at geoanalytic.com>:
>> >> > Does your settings.ini file have entries like
>> >> > [identify]
>> >> > identify_header=identify/header.html
>> >> > identify_footer=identify/footer.html
>> >> > wms_header=identify/wms_header.html
>> >> > wms_record=identify/wms_record.html
>> >> > wms_footer=identify/wms_footer.html
>> >> > and do the files pointed to by the wms_* entries exist in the
>> >> > htdocs\php
>> >> > folder?
>> >> > Best Regards,
>> >> > Brent Fraser
>> >> > On 9/19/2012 1:47 PM, Matej Mailing wrote:
>> >> >> Just now I have found out that in my case I have no "projection"
>> >> >> parameter sent into the identify.php when comparing to the working
>> >> >> parcels sample. We are using EPSG:4326 - could this be a problem?
>> >> >> Thanks,
>> >> >> Matej
>> >> >> 2012/9/19 Matej Mailing <mailing at tam.si>:
>> >> >>> Hi all,
>> >> >>> I was able to get parcels identification working, but my layer
>> >> >>> still
>> >> >>> doesn't work. When enabling debug messages in identify.php, I get
>> >> >>> the
>> >> >>> followint output:
>> >> >>> "Notice: Undefined index: wms_header in /path/php/identify.php on
>> >> >>> line
>> >> >>> 116
>> >> >>> Warning: file(): Filename cannot be empty in /path/php/identify.php
>> >> >>> on
>> >> >>> line 116
>> >> >>> Warning: implode(): Invalid arguments passed in
>> >> >>> on line 116
>> >> >>> Notice: Undefined index: wms_record in /path/php/identify.php on
>> >> >>> line
>> >> >>> 117
>> >> >>> on
>> >> >>> line 117
>> >> >>> on line 117
>> >> >>> Notice: Undefined index: wms_footer in /path/php/identify.php on
>> >> >>> line
>> >> >>> 118
>> >> >>> on
>> >> >>> line 118
>> >> >>> on line 118
>> >> >>> msQueryByPoint():
>> >> >>> in /path/php/identify.php on line 170"
>> >> >>> When turning off the debug mode, I get the same output as mentioned
>> >> >>> before: just coordinates of the point.
>> >> >>> Thanks for any ideas,
>> >> >>> Matej
>> >> >>> 2012/9/13 Eli Adam <eadam at co.lincoln.or.us>:
>> >> >>>> On Wed, Sep 12, 2012 at 4:24 PM, Matej Mailing <mailing at tam.si>
>> >> >>>> wrote:
>> >> >>>>> Hi,
>> >> >>>>> I have followed all 3 points, but with no success. I still get
>> >> >>>>> the
>> >> >>>>> coordinates and that's it ...
>> >> >>>> If you started with the demo, does identify on the parcels work?
>> >> >>>>> Now I have removed all the fields from the template file (that
>> >> >>>>> begins
>> >> >>>>> with the <!-- MapServer Template -->) so it only outputs some
>> >> >>>>> "hello
>> >> >>>>> world text", but it still doesn't work. I have now found a
>> >> >>>>> metadata="true" option available when defining the layer in the
>> >> >>>>> mapbook file, but also with this set to true it doesn't work. I
>> >> >>>>> have
>> >> >>>>> also added only this layer to be used for identify via <input
>> >> >>>>> type="hidden" name="layers" value="..."/> with no result :/
>> >> >>>>> What is the best way to debug this issue?
>> >> >>>> Firefox/firebug could be a good way to start. Using the firebug
>> >> >>>> console on the online demo leads to seeing things like:
>> >> >>>> post
>> >> >>>> dojo.preventCache 1347492736022
>> >> >>>> layers
>> >> >>>> blank%3Ablank/blank%3Aborders%3Aborders/city_labels%3Aborders/county_labels%3Aborders/city_poly%3Aborders/county_borders%3Aparcels%3Aparcels/parcels%3Asketch
>> >> >>>> projection EPSG%3A3857
>> >> >>>> shape POINT%28-10372969.112863%205552707.7829098%29
>> >> >>>> Source
>> >> >>>> layers=blank%253Ablank%2Fblank%253Aborders%253Aborders%2Fcity_labels%253Aborders%2Fcounty_labels%253Aborders%2Fcity_poly%253Aborders%2Fcounty_borders%253Aparcels%253Aparcels%2Fparcels%253Asketch&projection=EPSG%253A3857&shape=POINT%2528-10372969.112863%25205552707.7829098%2529&dojo.preventCache=1347492736022
>> >> >>>> response
>> >> >>>> <results><script> GeoMOOSE.clearLayerParameters('highlight');
>> >> >>>> GeoMOOSE.turnLayerOff('highlight/highlight');</script><html><![CDATA[<!--
>> >> >>>> Detailed information for the area you clicked on the map...
>> >> >>>> <table border="0">
>> >> >>>> <tr>
>> >> >>>> <td colspan="2"><b><u>Ground Coordinates</u></b>
>> >> >>>> <br>
>> >> >>>> <b>X: </b>485549.182735
>> >> >>>> <br>
>> >> >>>> <b>Y: </b>4934226.01043</td>
>> >> >>>> </tr>
>> >> >>>> <tr>
>> >> >>>> <td> </td>
>> >> >>>> <td> </td>
>> >> >>>> </tr>
>> >> >>>> </table>
>> >> >>>> <table border="0" cellpadding="1" cellspacing="2">
>> >> >>>> <tr bgcolor="#DEE5EB"><td colspan="2"><b><u>Parcels</u></b></tr>
>> >> >>>> <tr>
>> >> >>>> <td align="right"><b>PIN:</b></td>
>> >> >>>> <td>130260001175 <a
>> >> >>>> href="javascript:GeoMOOSE.startService('feature_report', {'PIN' :
>> >> >>>> '130260001175', 'src' : 'parcels/parcels'})">Report</a></td>
>> >> >>>> </tr>
>> >> >>>> <tr>
>> >> >>>> <td align="right"><b>Owner Name:</b></td>
>> >> >>>> <td>Thaddeus Garcia</td>
>> >> >>>> </tr>
>> >> >>>> <tr>
>> >> >>>> <td align="right"><b>Est. Market Value:</b></td>
>> >> >>>> <td>1178700</td>
>> >> >>>> </tr>
>> >> >>>> <tr>
>> >> >>>> <td align="right"><b>Acres:</b></td>
>> >> >>>> <td>154.37</td>
>> >> >>>> </tr>
>> >> >>>> <tr>
>> >> >>>> <td> </td>
>> >> >>>> <td> </td>
>> >> >>>> </tr>
>> >> >>>> ]]></html><footer><![CDATA[<b>Disclaimer: This information is
>> >> >>>> being
>> >> >>>> distributed as demonstation data only. You should not use the
>> >> >>>> data
>> >> >>>> for any other purposes.</b>
>> >> >>>> ]]></footer></results>
>> >> >>>> You can do the same with your site and see exactly what is coming
>> >> >>>> back
>> >> >>>> in the response. Posting more specific details (relevant parts of
>> >> >>>> mapbook.xml, ogrinfo of datasource) or providing a link to your
>> >> >>>> website might make it easier for people to make suggestions.
>> >> >>>> Getting
>> >> >>>> the parcels example working correctly and then closely matching
>> >> >>>> the
>> >> >>>> parcels set can be a starting place. Also confirm that relative
>> >> >>>> paths
>> >> >>>> are correct.
>> >> >>>> Best Regards, Eli
>> >> >>>>> Thanks for any ideas in advance ....
>> >> >>>>> Matej
>> >> >>>>>> Matej,
>> >> >>>>>> On Wed, Sep 12, 2012 at 3:52 PM, Matej Mailing <mailing at tam.si>
>> >> >>>>>> wrote:
>> >> >>>>>>> Hi,
>> >> >>>>>>> I have a layer where I have added
>> >> >>>>>>> METADATA
>> >> >>>>>>> 'identify_record'
>> >> >>>>>>> END
>> >> >>>>>>> and created a file in the subdirectory of the directory where
>> >> >>>>>>> the
>> >> >>>>>>> map
>> >> >>>>>>> file is. Identify service is active since when I click to some
>> >> >>>>>>> point
>> >> >>>>>>> I
>> >> >>>>>> Does your template start with:
>> >> >>>>>>> get the coordinates. This layer can be the only layer turned on
>> >> >>>>>>> in
>> >> >>>>>>> the
>> >> >>>>>>> Catalog, but I still get no identify results and the message
>> >> >>>>>>> containing the coordinates seems to be used.
>> >> >>>>>> Can you review this draft updated documentation and see if it
>> >> >>>>>> helps?
>> >> >>>>>> http://geomoose.org/trunk/howto/identify.html
>> >> >>>>>> HTH, Eli
>> >> >>>>>>> What am I doing wrong? I have been pulling my hair out for
>> >> >>>>>>> quite
>> >> >>>>>>> some
>> >> >>>>>>> hours now ...
>> >> >>>>>>> Thanks for all the ideas.
>> >> >>>>>>> Matej
>> >> >>>>>>> _______________________________________________
>> >> >>>>>>> Geomoose-users mailing list
>> >> >>>>>>> Geomoose-users at lists.osgeo.org
>> >> >>>>>>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
>> > Dean R Anderson
>> > IT Director
>> > Polk County
> Dean R Anderson
> IT Director
> Polk County
More information about the Geomoose-users
