[Geomoose-users] FYI: workaround found for feature reports not working
Mark Volz
MarkVolz at co.lyon.mn.us
Tue Sep 25 09:32:49 PDT 2012
Hello,
I reported that I was having trouble displaying the feature report for my parcels. At first I thought there was a problem with the primary id [PIN] (I originally changed the name), or with the coordinate systems. It turns out that the actual issue is that the feature report does not work when there are dashes in the pin number. For example when the PIN is 01-234567-8, the feature report does not work. If I remove the dashes so that the PIN is 012345678 then the feature report works.
I thought this might be a bug so I filled a ticket. In the meanwhile I will just strip off dashes from the PIN.
Thank you
Mark Volz
GIS Specialist
More information about the Geomoose-users
