[Geomoose-users] Soil acreage calculator?
Brian Fischer bfischer at houstoneng.com
Wed Apr 3 17:15:30 PDT 2013
We did something just like this with Door County WI but it used the selected parcel instead of a user input polygon.  http://map.co.door.wi.us/map  It would take a little programming but definitely doable with PostGIS.
Brian Fischer, CFM
Principal | GIS Project Manager
Houston Engineering, Inc.
O 763.493.4522 | D 763.493.6664 | M 763.229.2734
-----Original Message-----
From: geomoose-users-bounces at lists.osgeo.org [mailto:geomoose-users-bounces at lists.osgeo.org] On Behalf Of Brent Fraser
Sent: Tuesday, April 02, 2013 3:45 PM
To: Mark Volz
Cc: geomoose-users at lists.osgeo.org
Subject: Re: [Geomoose-users] Soil acreage calculator?
Mark,
   Use the GeoMoose Feature Editor tools for creating the user-sketched polygons.  In versions previous to GM v2.6 the Feature Editor was GM Javascript and PHP, so you could modify the PHP to do a PostGIS query to get the area values of the intersecting soil polygons (if they are in the PostGIS database too).  If PostGIS is not available, you might be able to use OGR or GEOS to do the area calculations in PHP (or Python for that matter).
Best Regards,
Brent Fraser
On 4/2/2013 12:55 PM, Mark Volz wrote:
> Hello,
> I would like to create a tool in GeoMOOSE that would allow a user to sketch in a polygon and get back the a report containing the total acreage of each soil type within the selection polygon?  Would a tool like this be easy, or possible to create?  Has anyone else done anything similar?
> Thanks
> Mark Volz
> GIS Specialist
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users mailing list
