[Geomoose-users] Linking search results to templates
Brent Fraser
bfraser at geoanalytic.com
Tue Apr 9 13:25:05 PDT 2013
I'm always paranoid when it comes to data, so I prefer to have a step
where I "load" the data and confirm the result. But as long as the data
is consistent (when does that happen?), maybe you could just modify the
PHP to:
1. get the contents of a directory where the photos are stored
2. parse the file names
3. and generate the output HTML.
Basically doing a "join" and template process in the PHP. Might be a
performance issue if there are thousands of photos in the dir....
Best Regards,
Brent Fraser
On 4/9/2013 2:11 PM, Bistrais, Bob wrote:
> Thanks Brent,
> Looks like most sites have 4 photos, but not all. I'm finding cases
> of fewer or more than 4 photos. Problem is, this could change as the
> customer adds more sites, or more photos to existing sites. So I'd
> have to modify a table every time the customer sends data updates. I
> was hoping maybe I could do this through MapServer templating?
> *From:*Brent Fraser [mailto:bfraser at geoanalytic.com]
> *Sent:* Tuesday, April 09, 2013 3:57 PM
> *To:* Bistrais, Bob
> *Cc:* geomoose-users at lists.osgeo.org
> *Subject:* Re: [Geomoose-users] Linking search results to templates
> Bob,
> Depends on the data. Are there usually 4 photos? If so, just create
> 4 columns in the Site table and populate them with the path to
> photos. If it is more variable (sometimes 1, sometimes 5 photos),
> create a table to relate Sites to Photos:
> SitePhotos
> siteID: photoPath:
> and do a table join within Mapserver's Map file (in the LAYER's DATA
> statement) to relate sites to tables.
> Best Regards,
> Brent Fraser
> On 4/9/2013 1:14 PM, Bistrais, Bob wrote:
> I'm working on an application which depicts various sites (several
> thousand of them). The customer has photos of the different
> sites, each site usually has 4 pictures, from different angles.
> The spatial data does not have an attribute linking the photos to
> a particular record. But each photo has the site ID as part of
> its name. Example- Site 1234 has photos with names like
> "1234Front.jpg", "1234Rear.jpg", etc.
> What I'd like to do is display search/query results so that the
> corresponding photos (actually, links to them) will appear in an
> Identify or query result tab. I can form the URL's based on the
> site's ID number, but don't know how to insert these into the
> identify/query templates.
> Has anyone done something similar to this, and would have any
> advice on how to do this?
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org <mailto:Geomoose-users at lists.osgeo.org>
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20130409/65e218f4/attachment-0001.html>
More information about the Geomoose-users
