[Geomoose-users] problem with Identify on Groups
Bistrais, Bob Bob.Bistrais at maine.gov
Fri Feb 1 11:03:17 PST 2013
OK, thanks.  I'll probably have to work up a similar hack.  Problem is, I don't want these layers to always identify, only when turned on.
From: Anderson, Dean [mailto:anderson.dean at co.polk.or.us]
Sent: Tuesday, January 29, 2013 12:22 PM
To: eadam at co.lincoln.or.us
Cc: Bistrais, Bob; geomoose-users at lists.osgeo.org
Subject: Re: [Geomoose-users] problem with Identify on Groups
Bob
I know this does not quite do it but I have an "IdentifyAll" service that just calls the identify.php.  This allows me to identify specific layers from a "hard wired" button. Seems to work OK. Below is how I call the identify.php from my mapbook.xml
<service name="identifyall" title="IdentifyAll" display="false">
                        <url>php/identify.php</url>
                        <step type="spatial" name="shape" show-tools="false" line="false" polygon="false" jump-start="true" default="point">
                                    <!-- <input type="visiblelayers" name="layers"/> -->
                        <input type="hidden" name="layers" value="taxlot2012/taxlot2012:taxlot/PolkTaxlots:cityugb/all:compplan/all:taxcode/all:zoning/all:roads/Roads:fire/all:school/Schools:precinct/all:garbage/all:waterut/all:powerut/all:soils/all:flood/all:wetland/wetland:elevation/all" />
                        </step>
</service>
I did this in 2.4 and have not tested it in 2.6.
Dean
On Tue, Jan 29, 2013 at 9:01 AM, Eli Adam <eadam at co.lincoln.or.us<mailto:eadam at co.lincoln.or.us>> wrote:
On Tue, Jan 29, 2013 at 8:16 AM, Bistrais, Bob <Bob.Bistrais at maine.gov<mailto:Bob.Bistrais at maine.gov>> wrote:
> I have a few map layers which I want to turn on/off by using the Group
> parameter in the map file.  In Mapbook.xml I can use the Group name and all
> the layers in the group turn on and off without problems.  The problem is,
> when I want to Identify layers in the group, Identify doesn't work (the
> error file says "query returned no results").  If I use the layer name of
> just one layer, the Identify will work, so there's nothing wrong with the
> layer definition.  But Identify doesn't seem to pay attention to Groups.  Is
> there a way I can get this to work?
There are docs on how to identify one or more specific layers,
http://geomoose.org/howto/identify.html#forcing-identify-to-always-identify-a-specific-layer
HTH, Eli
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org<mailto:Geomoose-users at lists.osgeo.org>
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
Dean R Anderson
IT Director
Polk County
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20130201/921ec483/attachment.html>
More information about the Geomoose-users mailing list
