[Geomoose-users] trouble with Select on file GDB
Bistrais, Bob Bob.Bistrais at maine.gov
Mon Feb 18 13:27:24 PST 2013
...one other thing, I tried a Select on a shapefile-based layer, this does highlight the result and returns the correct number of results (1 in this case).
From: geomoose-users-bounces at lists.osgeo.org [mailto:geomoose-users-bounces at lists.osgeo.org] On Behalf Of Bistrais, Bob
Sent: Monday, February 18, 2013 4:26 PM
To: geomoose-users at lists.osgeo.org
Subject: [Geomoose-users] trouble with Select on file GDB
I've noticed some trouble with the Select Features tool when using features in an ESRI FileGDB.  At first glance the query looks OK, in that I get the expected results in the result tab.  But, the "Found Shapes" line says 0 features found, and the resulting database is not populated, so nothing gets exported to csv or other output.  In addition, I'm not seeing the features highlighted on the map.  Is this a bug or am I doing something wrong?
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20130218/d1e38e56/attachment.html>
More information about the Geomoose-users mailing list
