[Geomoose-users] Mailing labels for different layers
Bistrais, Bob
Bob.Bistrais at maine.gov
Fri Feb 22 06:59:40 PST 2013
Thanks Mark. Upon further inspection, it looks like I don't need to do anything with the .ini file. I think by using the print_labels.php as a model I can create an output of my attributes to csv. The select.php in 2.6 creates a SQLite db file which contains the attributes of the selected set (it was a dbf in earlier versions). So by accessing that db file, I think I may be able to get the data to a report.
Sent: Friday, February 22, 2013 9:45 AM
To: Bistrais, Bob; geomoose-users at lists.osgeo.org
Subject: RE: Mailing labels for different layers
Bob,
I know at 2.2 the selection service creates a shapefile. If the selection service still works the same way at 2.6 then you could use the code on the wiki and create a shapefile which includes the attributes.
Mark Volz
GIS Specialist
Lyon County, MN
(507) 532-8218
From: geomoose-users-bounces at lists.osgeo.org<mailto:geomoose-users-bounces at lists.osgeo.org> [mailto:geomoose-users-bounces at lists.osgeo.org] On Behalf Of Bistrais, Bob
Sent: Thursday, February 21, 2013 1:59 PM
To: geomoose-users at lists.osgeo.org<mailto:geomoose-users at lists.osgeo.org>
Subject: [Geomoose-users] Mailing labels for different layers
I'd like to set up my mailing labels so that they can be used with several different queried layers. Each of these layers has different attributes (I'm not actually trying to make mailing labels, but just output the query results to CSV). The settings.ini file doesn't seem to allow this. I'm sorry if this has been asked before (searched, but didn't find anything), but has anyone else ever tried to do this, and what should be done to make this work?
This message was secured by ZixCorp<http://www.zixcorp.com>(R).
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20130222/ab3baf40/attachment.html>
More information about the Geomoose-users
