[Geomoose-users] select and query in postgis layers
Bistrais, Bob Bob.Bistrais at maine.gov
Tue Feb 19 10:21:23 PST 2013
I know this does not help you Luis, but it sounds the same as the problem I've been having, except my data is in ESRI File Geodatabase rather than PostGIS.  I get the "found shapes: 0" message and no highlight, but attributes are returned.
From: geomoose-users-bounces at lists.osgeo.org [mailto:geomoose-users-bounces at lists.osgeo.org] On Behalf Of Luis Calisto
Sent: Tuesday, February 19, 2013 1:08 PM
To: geomoose-users at lists.osgeo.org
Subject: [Geomoose-users] select and query in postgis layers
Hi
i'm working with geomoose version 2.6.1
I have some layers in shapefile but the most part is postgis.
Everything is ok except that with the postgis layers the select and the query services do not work. The select returns well the attributes but says that "Found Shapes: 0" and does not highlight any feature. The query service return no value at all. The select and the query service is fine with the shapefile based layers and the identify service is fine with both layers.
I followed the documentation in the demo but this documentation is made for shapefiles, maybe something is missing with my config.
Anyone can help?
Thanks
My configs are the folowing:
mapbook describing the query and the select services:
<service name="buffered_select" title="Select Features">
                                <url>php/select.php</url>
                                <!-- Send a selection shape + the visible layers list to the service -->
                                <step type="spatial" showTools="true" name="shape" line="true" polygon="true" point="true" default="polygon" edit-polygon="false" pan="false">
                                                <header><![CDATA[Create a selection area by clicking on the map.]]></header>
                                                <input type="visiblelayers" name="layers"/>
        Option values should be the mapbook path to the layer.
        This only supports 'mapserver'-type layers.
                                                <input type="select" name="select_layer" title="Select features from:">
        <option value="pontos_demo/pontos_demo">Pontos_demo</option>
        <option value="pontos_shp/pontos_shp">Pontos_shp</option>
        <option value="prov_shp/prov_shp">prov_shp</option>
                                                </input>
                                                <input type="user" name="select_buffer" title="Buffer Selected Features (m)">0</input>
                                                <input type="length" name="selection_buffer" title="Buffer Selection Shape">0</input>
                                                <input type="select" name="query_layer" title="Using Features In">
        <option value="">No Layer</option>
                                                </input>
                                                <input type="projection" name="projection"/>
                                                <footnote><![CDATA[
                                                ]]></footnote>
                                </step>
                </service>
                <service name="search_parcels" title="Search">
                                <url>php/query.php</url>
                                <step type="input">
                                                <input type="hidden" name="highlight" value="true"/>
                                                <input type="hidden" name="mode" value="search"/>
                                                <input type="hidden" name="layer0" value="pontos_demo/pontos_demo"/>
                                                <input type="hidden" name="template0" value="itemquery"/>
                                                <input type="select" name="fieldname0" title="Search By:">
        <option value="gid">ID</option>
                                                </input>
                                                <input type="select" name="comparitor0" title="That: ">
        <option value="like-icase">Contains</option>
        <option value="right-like-icase">Begins With</option>
        <option value="eq-str">Matches Exactly</option>
        <option value="in">In List</option>
                                                </input>
                                                <input type="user" name="value0" title=""/>
                                                <input type="hidden" name="fieldname1" value="FIN_SQ_FT"/>
                                                <input type="select" name="operator1">
        <option value="or">OR</option>
        <option value="and">AND</option>
                                                </input>
                                                <input type="select" name="comparitor1" title="Having Fin. Sq. Ft. ">
        <option value="gt">Greater Than</option>
        <option value="eq">Equal To</option>
        <option value="lt">Less Than</option>
                                                </input>
                                                <input type="user" name="value1" title=""/>
                                </step>
                </service>
map file of the postgis layer:
MAP
                NAME 'pontos_demo'
                SIZE 800 650
                STATUS ON
                EXTENT  19.069345 -27.742864 51.134315 -9.525530
                UNITS METERS
                INCLUDE "../../geomoose_globals.map"
                WEB
                                METADATA
                                                'ows_title' 'Pontos'
                                                'ows_srs' 'EPSG:4326 EPSG:3857'
                                                'ows_enable_request' '*'
                                                'ows_onlineresource' 'http://www.geomoose.org'
                                END
                END
                PROJECTION
                                'init=epsg:4326'
                END
                LEGEND
                     STATUS ON
                     LABEL
                                TYPE TRUETYPE
                                FONT vera_sans
                                SIZE 8
                                COLOR 0 0 0
                     END
                END
                LAYER
                 NAME 'pontos_demo'
                   TYPE POINT
                  DUMP true
                 CONNECTIONTYPE postgis
                 CONNECTION "dbname='atlas_mz' host=localhost port=5432 user='postgres' password='postgis' sslmode=disable"
                 DATA 'the_geom FROM "public"."pontos_sportgis" USING UNIQUE gid USING srid=4326'
      LABELITEM 'tipo_infra'
                                LABELCACHE ON
                                LABELMAXSCALE 500000
    CLASSITEM 'tipo'
    CLASS
      NAME "Estadio"
      EXPRESSION "1"
       STYLE
         SYMBOL "circle"
         SIZE 17.0
         OUTLINECOLOR 0 0 0
         COLOR 0 0 0
       END
     LABEL
      FONT vera_sans
      TYPE truetype
      SIZE 13
      COLOR 0 0 0
      ANGLE 0
      POSITION auto
      FORCE true
      ANTIALIAS true
      PARTIALS true
     END
    END
    CLASS
      NAME "Campo de futebol"
      EXPRESSION "2"
       STYLE
         SYMBOL "circle"
         SIZE 12
         OUTLINECOLOR 0 0 0
         COLOR 255 170 0
       END
     LABEL
      FONT vera_sans
      TYPE truetype
      SIZE 9
      COLOR 0 0 0
      ANGLE 0
      POSITION auto
      #FORCE true
      ANTIALIAS true
      PARTIALS true
     END
    END
    CLASS
      NAME "Campo de tenis"
      EXPRESSION "3"
       STYLE
         SYMBOL "circle"
         SIZE 7.0
         OUTLINECOLOR 0 0 0
         COLOR 255 0 0
       END
     LABEL
      FONT vera_sans
      TYPE truetype
      SIZE 9
      COLOR 0 0 0
      ANGLE 0
      POSITION auto
      #FORCE true
      ANTIALIAS true
      PARTIALS true
     END
    END
                                METADATA
                                                # drill-down identify service record.
                                                'identify_record'   'templates/identify.html'
                                                # query.php / "Search Parcels" functionality.
                                                'itemquery'            'templates/search_result.html'
                                                'itemquery-filter'   '/.*[qstring].*/i'
                                                'qstring_validation_pattern' '.'
                                                # Feature reports are stored in the conf/feature_report directory.
                                                'feature_report' 'parcel.xml'
                                                'select_record'      'templates/select_result.html'
                                                'select_header' 'templates/select_header.html'
                                                'popups' 'parcels_popup.html'
                                END
                                TOLERANCE 1
                                TOLERANCEUNITS PIXELS
                 END
END ## end Map
postgis table:
CREATE TABLE public.pontos_sportgis
  gid integer NOT NULL DEFAULT nextval('pontos_sportgis_gid_seq'::regclass),
  the_geom geometry(MultiPoint,4326),
  tipo_infra character varying(80),
  fotografia character varying(80),
  tipo smallint,
  nome character(50),
  CONSTRAINT pontos_sportgis_pkey PRIMARY KEY (gid )
WITH (
  OIDS=FALSE
ALTER TABLE public.pontos_sportgis
  OWNER TO postgres;
CREATE INDEX sidx_pontos_sportgis_the_geom
  ON public.pontos_sportgis
  USING gist
  (the_geom );
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20130219/85321179/attachment-0001.html>
More information about the Geomoose-users mailing list
