[Geomoose-users] coordinates showed in footer section
Jim Klassen klassen.js at gmail.com
Mon Jan 14 08:04:13 PST 2013
I believe it sets the default projection for use in the PHP services.  (It can be overridden in local_settings.ini)
I am not sure why the PHP services don't just key this off of the value set in the mapbook.
On Jan 14, 2013, at 3:23, Alejandro Garcia <alegarmen at gmail.com> wrote:
> Hi James, thanks a lot for your fast reply, it has been very useful
> I forgot the Google Satellite layer can not be reprojected, so my own layers are in the correct position with the correct coordinates, but Google layer was showed in a wrong way.
> Following the same subjet, in the file setting.ini there is a projection label fill with EPSG3857, how does work this label?
> thanks in advance
> 2013/1/11 James Klassen <klassen.js at gmail.com>
> The coordinates display in the same projection as the map is drawn in.  (Although this wouldn't necessarily have to be the case, but I don't believe anyone has requested otherwise yet.)
> Given that, it sounds like you may have skipped Step 4 (Updating <configuration> in the mapbook).
> Note: if you don't display in 3857/900913 you cannot use the common commercial tile sources for basemaps.
> On Fri, Jan 11, 2013 at 4:43 AM, Alejandro Garcia <alegarmen at gmail.com> wrote:
> Hello to all,
> I'm starting to prepare a map web viewer based on geomoose 2.6. All my data are in EPSG:32628, that is, UTM28N and WGS84. I followed the instruccions I found here (http://www.geomoose.org/docs/projections.html), but it doesn't work, I can see maps but not in the correct position by far. The aplication seems work always in EPSG:3857. I've seen even in the live demo (http://www.geomoose.org/demo/geomoose.html) coordinates showed are under EPSG:3857 specifications instead do it in EPSG:26915.
> As you can imagine, show the coordinates in our reference system is very important.
> What I'm doing wrong? any help?
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20130114/e181da0b/attachment.html>
More information about the Geomoose-users mailing list
