[Geomoose-users] coordinates showed in footer section
Jim Klassen
klassen.js at gmail.com
Mon Jan 14 14:15:19 PST 2013
Mark and others,
Would you want it to display the county and native XY at the same time? I'm just trying to figure out what the configuration would look like.
The "code" part is relatively simple.
Jim
On Jan 14, 2013, at 4:00 PM, Mark Volz wrote:
> Jim,
> At one time I thought it would be worthwhile to display coordinates on the bottom in different system than the map. One use case would be to draw a map using UTM 15 so I could take better advantage of the high speed state WMS server, while displaying coordinates in a county system that users care about.
> Mark Volz
> GIS Specialist
> From: geomoose-users-bounces at lists.osgeo.org [mailto:geomoose-users-bounces at lists.osgeo.org] On Behalf Of James Klassen
> Sent: Friday, January 11, 2013 9:59 AM
> To: Alejandro Garcia
> Cc: geomoose-users at lists.osgeo.org
> Subject: Re: [Geomoose-users] coordinates showed in footer section
> The coordinates display in the same projection as the map is drawn in. (Although this wouldn't necessarily have to be the case, but I don't believe anyone has requested otherwise yet.)
> Given that, it sounds like you may have skipped Step 4 (Updating <configuration> in the mapbook).
> Note: if you don't display in 3857/900913 you cannot use the common commercial tile sources for basemaps.
> On Fri, Jan 11, 2013 at 4:43 AM, Alejandro Garcia <alegarmen at gmail.com> wrote:
> Hello to all,
> I'm starting to prepare a map web viewer based on geomoose 2.6. All my data are in EPSG:32628, that is, UTM28N and WGS84. I followed the instruccions I found here (http://www.geomoose.org/docs/projections.html), but it doesn't work, I can see maps but not in the correct position by far. The aplication seems work always in EPSG:3857. I've seen even in the live demo (http://www.geomoose.org/demo/geomoose.html) coordinates showed are under EPSG:3857 specifications instead do it in EPSG:26915.
> As you can imagine, show the coordinates in our reference system is very important.
> What I'm doing wrong? any help?
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20130114/4c32d5a0/attachment.html>
More information about the Geomoose-users
