[Geomoose-users] WMS not working
Jim Klassen klassen.js at gmail.com
Wed Jul 3 13:22:18 PDT 2013
Let's take a step back...  "Nothing worked" doesn't give us much of a base line to help you from.
Do you have the stock 2.6.1 demo working?
What have you changed from the demo?
	Simplest would be to add the fsa2010 layer to the lmic.map file, then add the layer child to the map-source, and finally add the layer in the catalog.
	Have you tried to change the projection of the map from Web Mercator (3857) to UTM15 (26915)?  If so, you should be aware that the popular tiled layers (google, bing, osm, ...) won't work anymore, but as you are in Dakota County, there should be a good basemap available to you in 26915 that you could use instead.  Also, if you change projection, the max_extent, initial_extent, zoom_tos, will need to change to the new projection.  You may also want to look at changing numZoomLevels and maxResolution.
What does not working mean?
	Pink map?
	White map?
	No interface?
	And error messages? (And check in a JavaScript console too, like Firebug)
	Do other layers work?
The statewide fsa2010 layer from MNGeo isn't significantly different than the met10 layer that is in the demo already.
On Jul 3, 2013, at 3:01 PM, Dennis Tumberg wrote:
> Sorry, I had copied that to post it, but switched it to “on” before I posted, nothing worked.  I deleted status all together, it is still not working.
> Dennis Tumberg
> GIS Technician
> City of Inver Grove Heights
> Phone - 651.554.3446
> From: Paul Wickman [mailto:paul at flatrockgeo.com]
> Sent: Wednesday, July 03, 2013 2:57 PM
> To: Dennis Tumberg
> Cc: geomoose-users at lists.osgeo.org
> Subject: Re: [Geomoose-users] WMS not working
> Dennis,
> At first glance, try removing the ' status="off" ' setting on the <layer>
> On Wed, Jul 3, 2013 at 2:23 PM, Dennis Tumberg <dtumberg at invergroveheights.org> wrote:
> I have been working with GeoMOOSE just a short time and am having issues with getting a WMS layer to display.
> I have tried adding the WMS directly with and without a MAP file.
> Here is what I have for the map source and layer in catalog:
> <map-source name="fsa2010" type="wms" projection='EPSG:26915'>
>                 <url>http://geoint.lmic.state.mn.us/cgi-bin/wms?</url>
>                  <layer name="fsa2010" status="off"/>
>                 <param name="TRANSPARENT" value="true"/>
>                 <param name="FORMAT" value="image/png"/>
> </map-source>
> <layer title="2010 FSA" src="fsa2010/fsa2010" status="off" legend="false" fade="false" unfade="false"/>
> What am I doing wrong, I can’t seem to find any of the solutions with online searches.
> Thanks,
> Dennis Tumberg
> GIS Technician
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
> Paul Wickman
> CTO | Flat Rock Geographics
> 612.280.5850 | paul at flatrockgeo.com
> www.flatrockgeo.com | twitter.com/flatrockgeo
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20130703/3c7e2848/attachment.html>
More information about the Geomoose-users mailing list
