[Geomoose-users] Remove drawing tool layer from service without closing service tab.
Luis Calisto
luis.calisto at hotmail.com
Tue Jul 9 12:02:47 PDT 2013
But this lead me to another problem.
What is the name of the openlayers vector layer, the shape, that geomoose create when you use a service? because this is the layer that i want to remove! if i do a Application.getVisibleLayers(); this layer does not appear on the list.
Thanks for your patience
Luis
Date: Mon, 8 Jul 2013 07:13:31 -0700
Subject: Re: [Geomoose-users] Remove drawing tool layer from service without closing service tab.
To: luis.calisto at hotmail.com; geomoose-users at lists.osgeo.org
That's going to break when you add or remove layers.
This will be more reliable:
Application.getMapSource('NAME_OF_YOUR_LAYER')._ol_layer.removeAllFeatures();
Not the cleanest, but it will not break when you change your layers around.
To: Dan Little <danlittle at yahoo.com>; "geomoose-users at lists.osgeo.org" <geomoose-users at lists.osgeo.org>
Sent: Wednesday, July 3, 2013 9:33 AM
Subject: RE: [Geomoose-users] Remove drawing tool layer from service without
well for me its enough to remove the features from the drawing layer. I can do this with the following javascript code: window.Map.layers[28].removeAllFeatures();
but this code is not the most beautifull solution! what do you thing?
thanks!Luís
Date: Mon, 1 Jul 2013 11:04:07 -0700
Yes, but it's going to be a bit hacky, we don't have an API exposed to 'switch the
tool'. I looked around in the code and I don't see an easy/obvious answer.
I'd love to see the code for anything you work out! Thanks!
To: Dan Little
Sent: Monday, July 1, 2013 12:44 PM
Hi
yes, want to disable drawing on the map but keep up the tab. Is it possible?
Thanks in advance
Luís Calisto
Date: Mon, 1 Jul 2013 10:31:16 -0700
Can you give a little more information? Some pictures? I think I need a bit more description to understand what you're trying to do.
Are you trying
to disable drawing on the map but keep up a tab?
To: "geomoose-users at lists.osgeo.org" <geomoose-users at lists.osgeo.org>
Sent: Friday, June 28, 2013 1:18 PM
Subject: [Geomoose-users] Remove drawing tool layer from service without
Hello all,
i'm creating some services and at the end i want to remove the drawing tool layer from service without closing service tab. Is it possible with javascript?
anyone tried this?
Thank you
Geomoose-users mailing list
Geomoose-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20130709/45c62bdc/attachment.html>
More information about the Geomoose-users
