[Geomoose-users] GM 2.6 search results do not display - Resolved
Mark Volz MarkVolz at co.lyon.mn.us
Fri Jul 12 07:25:28 PDT 2013
Hello,
I was able to correct this problem.  One of the other layers that I copied and pated from GeoMOOSE 1.6 had header, template, and footer set in the layer block.  Everything works now that those lines are commented out
LAYER   # My 1.6 Layer
       HEADER 'popup_city_header.xml'
       TEMPLATE 'popup_city_record.xml'
       FOOTER 'popup_city_footer.xml'
Mark Volz, GISP
GIS Specialist
> -----Original Message-----
> From: geomoose-users-bounces at lists.osgeo.org [mailto:geomoose-users-
> bounces at lists.osgeo.org] On Behalf Of Mark Volz
> Sent: Thursday, July 11, 2013 3:27 PM
> To: geomoose-users at lists.osgeo.org
> Subject: [Geomoose-users] GM 2.6 search results do not display
> Hi,
> I am able to get parcels to highlight when searching in GeoMOOSE 2.6
> however, somewhere along the line I broke the code so that the results do
> not display under "GeoMOOSE Item Query Results."  Where should I start
> debugging the code so I can get my results back?
> Thanks
> Mark Volz, GISP
> GIS Specialist
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users mailing list
