[Geomoose-users] Unsupported output format (image/png;bits=8)
Robert R. Raiz raizrobert at gmail.com
Tue Jul 23 22:53:38 PDT 2013
Hello Brent,
I tried but I get the same error:
"msWMSLoadGetMapParams(): Image handling error. Unsupported output format
(image/png;bits=8)."
Maybe it has something to do with how MapSever was installed. I'll try the
mailing list over there to find a way to solve this.
On Tue, Jul 23, 2013 at 5:53 PM, Brent Fraser <bfraser at geoanalytic.com>wrote:
>  Try
> MIMETYPE "image/png; mode=8bit"
> Best Regards,
> Brent Fraser
> On 7/23/2013 8:10 AM, Robert R. Raiz wrote:
> Hello Mark,
> Sorry, I forgot to mention that I am not using at all geomoose_globals.map
> I've set my parameters to use my simbolset, fonts.. the only thing I kept
> from geomoose_globals. map is the WEB-METADATA section.
> If I paste in the mapfile what you just forwarded..well..I keep getting
> the same message:
> <?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?>
> <!DOCTYPE ServiceExceptionReport SYSTEM "
> http://schemas.opengis.net/wms/1.1.1/exception_1_1_1.dtd">
> <ServiceExceptionReport version="1.1.1">
> <ServiceException code="InvalidFormat">
> (image/png;bits=8).
> </ServiceException>
> </ServiceExceptionReport>
> I tried all the outputformats in the mapserver documentation but I keep
> getting this error. I thought it is hard-coded somewhere to use the
> outputformat mentioned in the first email.
> On Tue, Jul 23, 2013 at 4:33 PM, Mark Volz <MarkVolz at co.lyon.mn.us> wrote:
>>  Robert,
>> geomoose_globals.map, which is included on most of the demo map files
>> assigns png8 as the default output format.  This format works well for
>> vector layers, but not raster layers.  You might want to change your map
>> file like such:
>> #do not include geomoose globals which uses png8
>> #Include ../ geomoose_globals.map
>> #add the portions from geomoose_globals that you need
>>                 FONTSET              "../../fonts/fontset.list"
>>                 SYMBOLSET        "../../symbols/symbol.sym"
>>                 # prevent the pink screen of death on large monitors
>>                 MAXSIZE 10000
>>                 #TRANSPARENT TRUE
>>                 # Does this stuff even need to be set in MS 6.x?  JSK
>>                 OUTPUTFORMAT
>>                                 NAME 'agg/png'
>>                                 DRIVER AGG/PNG
>>                                 IMAGEMODE RGBA
>>                                 FORMATOPTION "TRANSPARENT=TRUE"
>>                                 TRANSPARENT ON
>>                                 MIMETYPE "image/png"
>>                 END
>>                 IMAGETYPE agg/png    # use the output format named
>> ‘agg/png’
>>                 IMAGECOLOR 255 255 255
>> Mark Volz, GISP
>> GIS Specialist
>> *From:* geomoose-users-bounces at lists.osgeo.org [mailto:
>> geomoose-users-bounces at lists.osgeo.org] *On Behalf Of *Robert R. Raiz
>> *Sent:* Tuesday, July 23, 2013 8:04 AM
>> *To:* geomoose-users at lists.osgeo.org
>> *Subject:* Re: [Geomoose-users] Unsupported output format
>> (image/png;bits=8)
>> Sorry, somehow gmail keyboard shortcuts made a fool out of me and sent
>> the email to soon;
>> The problem is that now, all my png images (PIXMAP) render really badly.
>> They look quite bad.
>> Whatever I try to modify in the map file at the OUTPUTFORMAT parameter, I
>> keep getting:
>> (image/png;bits=8).
>> I tried to change every parameter but I still get that error. If I use MIMETYPE
>> "image/png;bits=8" it works with vector files, but my icons (PIXMAP - png
>> images) do not render well.
>> Any Ideas?
>> On Tue, Jul 23, 2013 at 4:00 PM, Robert R. Raiz <raizrobert at gmail.com>
>> wrote:
>> Hello all,
>> I am struggling with this error.
>> In the past (with Mapserver5) I was using:
>>     IMAGETYPE png24
>> OUTPUTFORMAT
>> NAME 'AGGA'
>> DRIVER 'AGG/PNG'
>> IMAGEMODE RGBA
>> EXTENSION "png"
>> END
>> Now I have:
>> OUTPUTFORMAT
>> NAME "png8"
>> DRIVER AGG/PNG8
>> MIMETYPE "image/png;bits=8"
>> EXTENSION "png"
>> TRANSPARENT ON
>> IMAGEMODE RGBA
>> FORMATOPTION "QUANTIZE_FORCE=on"
>> FORMATOPTION "QUANTIZE_COLORS=256"
>> FORMATOPTION "INTERLACE=OFF"
>> END
>> *Raiz Roland Robert*
> Geomoose-users mailing listGeomoose-users at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20130724/5f5fb5d9/attachment.html>
More information about the Geomoose-users mailing list
