[Geomoose-users] strange problem with select
Eli Adam
eadam at co.lincoln.or.us
Wed Jul 31 08:20:02 PDT 2013
Bob,
On Tue, Jul 30, 2013 at 1:29 PM, Bistrais, Bob <Bob.Bistrais at maine.gov>wrote:
> I am working on a GM parcel application (GM 2.6.1). I was testing the
> buffered select service. With no buffering (just select by mouse), it
> seems to work fine. On the buffered select I encounter a weird problem.
> If you select a parcel, set a buffer distance and query layer (the
> parcels), click Go- it selects only a few of the surrounding parcels. In
> other words, if I set a buffer distance of 50 or 100 I’d expect to get all
> adjacent parcels selected, but it only selects some of the expected result.
Is it random which ones are selected? Is it a shift one way or the other?
Area you able to see this in the demo? Are some never selected? Do you
know if you have invalid/odd geometries or data in those areas? If you
have a PostGIS instance handy, you might want to load it up and run
ST_IsValid (http://postgis.net/docs/manual-2.0/ST_IsValid.html) or similar
functions to see if there is any pattern of this problem with something
that might be in the data.
This isn't a lot of detail to try and figure it out. You might be able to
get more info from checking the requests and responses in firebug (i.e.
perhaps it is a bad request vs. bad response vs. bad handling of a correct
response, etc).
I hope these ideas lead to something useful.
Eli
> The data is a shapefile, if that matters. Although I had started
> modifying the select.php for my project, I went back to the original when I
> discovered the problem, and it’s still doing it. Any idea what’s going on?
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20130731/cad1f4a8/attachment.html>
More information about the Geomoose-users
