[Geomoose-users] My Data Projected in wrong area
James Klassen
klassen.js at gmail.com
Thu Mar 28 04:35:42 PDT 2013
Check with another WMS client (such as QGIS) if MapServer is projecting
your data correctly. What does your MapServer LAYER look like?
For most WMS clients to work OWS_ONLINERESOURCE should point to your
mapfile not the geomoose website.
It looks like you may have a space in EPSG:32748 in settings.INI, but that
wouldn't cause your problem.
You don't need to edit config.js. The values in the map book will override
those in config.js. (Also I think config.js gets compiled in during the
build so changes there would only take effect if you rebuilt GeoMoose or
were using GeoMoose_Dev.html.)
On Mar 28, 2013 5:36 AM, "INDRA BAYU" <cucuberlian at gmail.com> wrote:
> I am new to GeoMoose. I use GeoMoose 2.6.1. I have added my data and
> have it projecting. The data is all WGS_1984_UTM_Zone_48S. I needed
> EPSG: 32748 fo this data. I added the new EPSG as per the GeoMoose
> instructions on http://www.geomoose.org/docs/projections.html.
> this is my configuration:
> ====EPSG32748.js====
> Proj4js.defs["EPSG:32748"] = "+proj=utm +zone=48 +south +ellps=WGS84
> +datum=WGS84 +units=m +no_defs";
> =====geomoose.html======
> <script type="text/javascript" src="projections/EPSG32748.js"></script>
> <script type="text/javascript" src="projections/EPSG26915.js"></script>
> <script type="text/javascript" src="projections/EPSG3857.js"></script>
> =====myshapefile.shp=========
> EXTENT 681064.622758 9296398.489077 696909.822267 9311182.143822
> WEB
> METADATA
> 'ows_title' 'Parcel Maps'
> 'ows_srs' 'EPSG:32748 EPSG:26915 EPSG:4326 EPSG:900913
> EPSG:3857'
> 'ows_enable_request' '*'
> 'ows_onlineresource' 'http://www.geomoose.org'
> END
> END
> PROJECTION
> 'init=epsg:32748'
> END
> =====mapbook.xml=======
> <param name="projection">EPSG:32748</param>
> <param
> name="max_extent">681064.622758,9296398.489077,696909.822267,9311182.143822</param>
> <param
> name="initial_extent">681064.622758,9296398.489077,696909.822267,9311182.143822</param>
> =====settings.ini====
> [defaults]
> ; Location of the default mapbook
> mapbook=mapbook.xml
> [map]
> projection=EPSG: 32748
> ===config.js====
> var CONFIGURATION = {
> 'links_bar_html' : "",
> 'waiting_html' : 'Loading...',
> 'mapserver_url' : "",
> 'control_panel_side' : 'left',
> 'mapfile_root' : "",
> 'mapbook' : "php/getmapbook.php",
> 'fractional_zoom' : false,
> 'scales' : [1,2,4,8,16,32,64,128,256,500,1000,5000],
> 'max_extent' :
> [681064.622758,9296398.489077,696909.822267,9311182.143822],
> 'initial_extent' :
> 'projection' : "EPSG:32748",
> 'ground_units' : 'm',
> My data is being projected on nowegian sea (my data is in indonesia) .
> Does anyone know what I am doing wrong?
> Thanks
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20130328/d8c2c014/attachment-0001.html>
More information about the Geomoose-users
