[Geomoose-users] Who here is still supporting IE7?
    Eli Adam
    eadam at co.lincoln.or.us
    Fri May  3 15:01:16 PDT 2013
IE 8+ seems reasonable.  I'll ping a few others too.
Eli
On Fri, May 3, 2013 at 9:55 AM, Basques, Bob (CI-StPaul) <
bob.basques at ci.stpaul.mn.us> wrote:
>  All,****
> We’ve (fairly recently) moved to IE 8/9 here at the City.  Still some IE7
> floating around, but this would just be the push to get them to move on
> too.  Majority are also on Win7 now.  Only have a couple of folks using
> IE10 currently.****
> Bobb****
> *From:* geomoose-users-bounces at lists.osgeo.org [mailto:
> geomoose-users-bounces at lists.osgeo.org] *On Behalf Of *Dan Little
> *Sent:* Friday, May 03, 2013 7:50 AM
> *To:* GeoMOOSE Users List
> *Subject:* [Geomoose-users] Who here is still supporting IE7?****
> FOSS4G/NA will allow for us to do some direction planning and legacy
> browser support is a subject upon which I intend to tackle this year.
>  Legacy support with IE is causing us problems with IE10. Some of the
> feature-sniffing code in IE10 makes things *very* difficult and newer
> versions of our base libraries that support IE10 tend to break IE6/7/FF<3.6.
> http://gs.statcounter.com/#browser_version_partially_combined-US-monthly-201302-201304-bar
> If you value GeoMOOSE simply BECAUSE of IE6/7 support then we'll need to
> hear from you.  Another motivating factor: I cannot seem to *buy* a version
> of Windows that will run IE7 anymore.  My only functioning windows install
> is Win7 and I believe I've got it upgraded to IE10 at this point, for
> testing purposes.  I'm going to try and setup a down-grade VM for IE9
> testing along with some automation.  ****
> Thanks all for any feedback.****
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20130503/1cdde819/attachment.html>
More information about the Geomoose-users
