[Geomoose-users] GeoMOOSE Demo application - Can't find a way to display my layers -reg.
James Klassen klassen.js at gmail.com
Mon May 20 05:53:14 PDT 2013
The error is saying that 283000 is an invalid latitude.  (You have GeoMoose
set to 4326 which is WGS84 lat,lon but with an extent that goes beyond
+/-180 lon and +/-90 lat.)
I think you are mixing EPSG:3857 and 4326.
All of your extents look like 3857 coordinates to me.  (Mapbook and
Mapfile).
My guess is what you want is to set the projections back to 3857 and add a
projection block to your layer in the .map file to tell MapServer the
source data projection is 4326.  Then MapServer will convert to 3857 before
sending to GeoMoose.
On May 20, 2013 12:00 AM, "Jaisen Nedumpala" <jaisuvyas at gmail.com> wrote:
> Hi,
>   Sorry for this late reply, as I was busy with some other tasks. Returned
> to this now only. My projection and extent settings are as follows:
> 1. Extends and SRS in Layer metadata as appeared in QGIS:
>     Extents: In layer spatial reference system units : xMin,yMin
> 600731.56,1298462.88 : xMax,yMax 613935.62,1304759.25
>     Layer Spatial Reference System: +proj=longlat +ellps=WGS84
> +datum=WGS84 +no_defs
>     (+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs +towgs84=0,0,0
> corresponds to EPSG:4326)
> 2. Projection and extents in the configuration section in mapbook.xml
>          <param name="projection">EPSG:4326</param>
>         <param name="zoomto"><![CDATA[
>             "Jump To:" : {
>                 "World" :
> [-20614760.777156,1751325.1919492,-1927436.1053437,7915207.1517617],
>                 "Parcel Data" :
> [-10384069.859924,5538318.529767,-10356632.423788,5563580.927174],
>                 "Full State of MN" : [-10742765,5398288,-9920914,6310641],
>                 "Village Panchayat" :
>         ]]></param>
> (I used here the same extend for the World in demo, for my layer because I
> don't know how to convert the extents in map file for the use of
> mapbook.xml. How? I know that here I did a mistake, how to correct it?)
> 3. local_settings.ini has following values only:
> [paths]
> root=/var/www/geo/geomoose-2.6.1/maps/
> mapserver_url=/cgi-bin/mapserv
> temp=/var/www/geo/geomoose-2.6.1/out/
> 4. settings.ini has following values:
> [defaults]
> ; Location of the default mapbook
> mapbook=mapbook.xml
> timezone=Asia/Kolkata
> [map]
> projection=EPSG:4326
> [paths]
> server_name=localhost
> 5. Map file landuse.map has following values:
>     EXTENT  600731.56 1298462.88 613935.62 1304759.25
>     UNITS METERS
>     WEB
>         METADATA
>             'ows_title' 'Land use Map'
>             'ows_srs' 'EPSG:26915 EPSG:4326 EPSG:900913 EPSG:3857
> EPSG:32643 EPSG:4326'
>             'ows_enable_request' '*'
>             'ows_onlineresource' 'http://www.geomoose.org'
>         END
>     END
>     PROJECTION
>         'init=epsg:4326'
>     END
> 6. GeoMOOSE returns an error messge with these settings as follows:
> X,Y: -12278844, 283734Lat, Lon: 283734.252, -12278844.225USNG: error
> lat283734.25174401 must be between in (-90,90)... no playing at the poles,
> yet
> I am not at all playing at poles that I know.. :) Where it went wrong? How
> to fix it? Can anybody help me?
> 2013/5/10 James Klassen <klassen.js at gmail.com>
>> Look at the projection and extents in the configuration section in
>> mapbook.xml and the projection in local_settings.ini
>> As a warning, layers like Google/Bing/OpenStreetMap tiles only work with
>> the demo projection/scales/max extent.  WMS layers will be fine in any
>> projection supported by the wms server.
>> On May 10, 2013 1:04 AM, "Jaisen Nedumpala" <jaisuvyas at gmail.com> wrote:
>>> Hi,
>>> I am Jaisen, new to GeoMOOSE.
>>> I was trying to make up my data with GeoMOOSE. As I am new, I did only
>>> minor changes in the demo application, as described in the documentation
>>> "How To Add Layers". But I couldn't visualise my data in GeoMOOSE. I don't
>>> understand where lies the problem. Please help me. What I did is described
>>> below:
>>> Created /var/www/geo/geomoose-2.6.1/htdocs/projections/EPSG32643.js with
>>> content following:
>>> Proj4js.defs["EPSG:32643"] = "+proj=utm +zone=43 +ellps=WGS84
>>> +datum=WGS84 +units=m +no_defs +towgs84=0,0,0";
>>> Created /var/www/geo/geomoose-2.6.1/htdocs/projections/EPSG4326.js with
>>> content following:
>>> Proj4js.defs["EPSG:4326"] = "+proj=longlat +ellps=WGS84 +datum=WGS84
>>> In /var/www/geo/geomoose-2.6.1/htdocs/geomoose.html
>>> Added following as line 59 and 60:
>>> <script type="text/javascript" src="projections/EPSG32643.js"></script>
>>> <script type="text/javascript" src="projections/EPSG4326.js"></script>
>>> In
>>> /var/www/geo/geomoose-2.6.1/maps/demo/statedata/basemap.map
>>> /var/www/geo/geomoose-2.6.1/maps/demo/parcels/parcels.map
>>> /var/www/geo/geomoose-2.6.1/maps/demo/wms/lmic.map
>>> /var/www/geo/geomoose-2.6.1/maps/demo/wms/usgs.map
>>> Added
>>> for 'ows_srs' parameter in METADATA section.
>>> Created directory /var/www/geo/geomoose-2.6.1/maps/edavaka/landuse/
>>> placed landuse.map in it.
>>> Added following lines as line 100-104 to
>>> /var/www/geo/geomoose-2.6.1/conf/mapbook.xml
>>> <map-source name="Landuse" type="mapserver">
>>>         <file>./edavaka/landuse/landuse.map</file>
>>>         <layer name="landuse" status="on"/>
>>>         <param name="FORMAT" value="image/png;bits=8"/>
>>>     </map-source>
>>> Added following lines as 387-391 to
>>>             <group title="Panchayat Layers" expand="false">
>>>                 <layer title="Land use" src="Landuse/landuse"
>>> metadata="true" legend="true" tip="Land use and land cover"
>>> show-legend="true">
>>>                 <metadata>http://www.geomoose.org/docs/</metadata>
>>>                 </layer>
>>>             </group>
>>> Content of landuse.map is follows:
>>> MAP
>>>     NAME 'landuse'
>>>     SIZE 800 650
>>>     STATUS ON
>>>     EXTENT  600200.710627 1297963.898875 614053.022957 1305268.779057
>>>     UNITS METERS
>>>     INCLUDE "../../geomoose_globals.map"
>>>     WEB
>>>         METADATA
>>>         END
>>>     END
>>>     PROJECTION
>>>         'init=epsg:4326'
>>>     END
>>>     LEGEND
>>>           STATUS ON
>>>           LABEL
>>>         TYPE TRUETYPE
>>>         FONT vera_sans
>>>         SIZE 8
>>>         COLOR 0 0 0
>>>           END
>>>     END
>>>       LAYER
>>>         NAME landuse
>>>             CONNECTIONTYPE postgis
>>>             CONNECTION "dbname='mydb' host=localhost port=5432
>>> user='jaisen' password='mypassword' sslmode=allow"
>>>             DATA 'the_geom FROM "landuse" USING UNIQUE gid USING
>>> srid=4326'
>>>             STATUS ON
>>>         TYPE POLYGON
>>>         LABELITEM 'PIN'
>>>         LABELCACHE ON
>>>         LABELMAXSCALE 20000
>>>         FILTER ([PARC_CODE] == 1)
>>>         CLASS
>>>             NAME 'Landuse'
>>>             STYLE
>>>                 WIDTH 3
>>>                 COLOR -1 -1 -1
>>>                 OUTLINECOLOR 93 181 53
>>>                 MAXSCALEDENOM 15000
>>>             END
>>>             STYLE
>>>                 SIZE 1
>>>                 COLOR -1 -1 -1
>>>                 OUTLINECOLOR 33 106 43
>>>             END
>>>             LABEL
>>>                 TYPE TRUETYPE
>>>                 FONT vera_sans
>>>                 SIZE 8
>>>                 ANTIALIAS TRUE
>>>                 COLOR 0 0 0
>>>                 OUTLINECOLOR 254 254 200
>>>                 BUFFER 4
>>>                 MINFEATURESIZE auto
>>>                 PARTIALS FALSE
>>>                 POSITION cc
>>>             END
>>>         END
>>>         METADATA
>>>             # drill-down identify service record.
>>>                   'identify_record'    'templates/identify.html'
>>>             # query.php / "Search Parcels" functionality.
>>>             'itemquery'    'templates/search_result.html'
>>>             'itemquery-filter'    '/.*[qstring].*/i'
>>>             'qstring_validation_pattern' '.'
>>>             # Feature reports are stored in the conf/feature_report
>>> directory.
>>>             'feature_report' 'parcel.xml'
>>>                   'select_record'    'templates/select_result.html'
>>>             'select_header' 'templates/select_header.html'
>>>             'popups' 'parcels_popup.html'
>>>         END
>>>         TOLERANCE 0
>>>         END
>>> END ## end Map
>>> - നെടുമ്പാല ജയ്സെന്‍ -
>>> «´¨`·* .  Jaisen . *..´¨`»
>>>       ( `v´ )
>>>         `v´
>>> Geomoose-users mailing list
>>> Geomoose-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
>       ( `v´ )
>         `v´
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20130520/8c55e295/attachment-0001.html>
More information about the Geomoose-users mailing list
