[Geomoose-users] IE 10 and GeoMoose 2.4 Fix
    Dan Little
    danlittle at yahoo.com
    Sat May 25 14:09:03 PDT 2013
Carrie,
Can you file this as a ticket for GM 2.6.2?  This may help folks with newer versions of GeoMOOSE also.
>________________________________
> From: Carrie Quast <Carrie.Quast at co.brown.mn.us>
>To: geomoose-users at lists.osgeo.org
>Sent: Tuesday, May 21, 2013 11:45 AM
>Subject: [Geomoose-users] IE 10 and GeoMoose 2.4 Fix
>Hello All -
>Microsoft must have pushed out an update on Windows 7 and above machines to update IE to IE 10 over the weekend.  I had a bunch of calls from the public about our GIS site not loading.  It only loads the HTML stuff, so the HTML Frame loads, but not the Javascript or PHP, etc. After a bit of searching, I found that adding this code to the header:
><meta http-equiv="X-UA-Compatible" content="IE=EmulateIE8" >
>This seemed to fix the problem.  I only tested it on one computer running windows 7 (all I have available) so if this doesn't work for you - please let me know.  You need to add right below the <head> tag in the geoomoose.html file, otherwise IE doesn't read it.
>My sources for this are:
>http://stackoverflow.com/questions/15387325/force-ie10-to-run-in-ie10-compatibility-view
>and
>http://msdn.microsoft.com/en-us/library/ie/jj676915.aspx
>Thank You - Carrie
>Carrie Quast, Brown County GIS Specialist/Webmaster
>14 South State Street
>New Ulm MN  56073
>Phone:  (507) 233-6633
>Fax:  (507) 359-1430
>_______________________________________________
>Geomoose-users mailing list
>Geomoose-users at lists.osgeo.org
>http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20130525/d8c8c2ec/attachment.html>
More information about the Geomoose-users
