[Geomoose-users] EPSG vs ESRI code issue
James Klassen klassen.js at gmail.com
Thu Nov 7 06:12:34 PST 2013
You are right, GeoMoose isn't converting coordinates to Lat Lon and that is
causing that error message.
On Nov 7, 2013 3:14 AM, "Robert R. Raiz" <raizrobert at gmail.com> wrote:
> I just realized that the problem might be from the fact that it cannot
> make the proj conversion.
> A working file, with EPSG code, shows *"X,Y: 3782392, 9991050Lat, Lon:
> 29.989, -95.639USNG: 15R TP 454 204"*
> while the current file shows the error
> *"X,Y: 790038, 980044Lat, Lon: 980043.878, 790037.752USNG: error
> lat980043.8781887802 must be between in (-90,90)... no playing at the
> poles, yet" *
> As I have an ESRI code in this case, I wonder if there is anyone out there
> who figured out how to fix this issue.
> Cheers,
> On Thu, Nov 7, 2013 at 10:36 AM, Robert R. Raiz <raizrobert at gmail.com>wrote:
>> Hello again,
>> I am still struggling with this. I added all those. I do not get the pink
>> screen. just white background and the message:
>> poles, yet"*
>> I read about this in the forums but I do not know what the issue is.. the
>> shapefile layer looks quite ok. I do not see problems there..
>> On Tue, Nov 5, 2013 at 11:55 PM, TC Haddad <tchaddad at gmail.com> wrote:
>>> If you are treating this as a fake EPSG code (which does work), you
>>> definitely need to also add it to your Mapserver EPSG file, so that
>>> Mapserver knows how to handle it when it ses in in the map file.
>>> Make sure that the EPSG file you add it to is the one that your copy of
>>> Mapserver is actually using (you may have more than one copy of the EPSG
>>> codes on your system).
>>> On Tue, Nov 5, 2013 at 8:12 AM, Robert R. Raiz <raizrobert at gmail.com>wrote:
>>>> Hello all,
>>>> I am trying to view some data in MO state ESRI projection. Is there any
>>>> reason why GeoMOOSE would not work with the ESRI projection considering the
>>>> following changes?
>>>> I created an ESRI102697.js file in the /../projections folder with the
>>>> following params:
>>>> *Proj4js.defs["ESRI:102697"] = "+proj=tmerc +lat_0=35.83333333333334
>>>> +lon_0=-92.5 +k=0.9999333333333333 +x_0=500000.0000000002 +y_0=0
>>>> +ellps=GRS80 +datum=NAD83 +to_meter=0.3048006096012192 +no_defs ";*
>>>> I added the *<script type="text/javascript"
>>>> src="projections/ESRI102697.js"></script>* line in the *geomoose.html*file.
>>>> Is there anything else I would need to do in order to make this work
>>>> (except a valid mapfile, of course)? I checked the docs (
>>>> http://docs.geomoose.org/2.6/docs/projections.html#include-the-javascript-file-in-your-html)
>>>> but I still am not sure if ESRI codes would work.
>>>> *Raiz Roland Robert*
>>>> _______________________________________________
>>>> Geomoose-users mailing list
>>>> Geomoose-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20131107/1cf3d7df/attachment-0001.html>
More information about the Geomoose-users mailing list
