[Geomoose-users] Edit select type attributes in vector layer.
Luis Calisto luis.calisto at hotmail.com
Tue Nov 19 07:02:06 PST 2013
I'm working with the vector layers and the feature attribute edit tool, all works great but i can't put working an attribute that is configured in the mapbook with the type "select".
In the demo mapbook example, the vector layer "sketch" there is a commented line:		<attribute name="opacity" type="select" default-value="100" label="Opacity (%):"/>
If i uncomment this line when i select the "edit attributes" tool it gives this error in the console: "Uncaught TypeError: Cannot call method 'getElementsByTagName' of null "
I changed the attribute options in the mapbook demo to:
<attribute name="opacity" type="select" default-value="100" label="Opacity (%):">		<option value="0">0</option>		<option value="50">50</option></attribute>
But same error! Any idea? Is it possible to use the select type in the vector attributes?
Best regardsLuís Calisto
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20131119/4289f3f4/attachment.html>
More information about the Geomoose-users mailing list
